Like Tree2Likes
Xray T3 2011
Old 07-19-2011, 08:30 AM
  #2581
Fred Hubbard's Avatar
Originally Posted by johnny55
Fred, I used that stuff last night to clean my chassis. I was impressed! Where can I get some of that gum?
Anywhere they sell nitro products
Fred Hubbard is offline
Old 07-19-2011, 09:09 AM
  #2582
johnny55's Avatar
Good Lookin!
johnny55 is offline
Old 07-19-2011, 01:32 PM
  #2583
Hello from France,
the XRay gear diferential is great.
The gears are made from a good nylon, the axles cross too.
The outdrives are made from treated aluminium.
The sealing is operated with flat-paper seal and an O-Ring.
Here's some weight about the T3 transmission...
The spool:
The ball dif:
The SpecR gear dif:
The XRay gear dif:
Front and rear difs in my car.
Au revoir.
romuald31 is offline
Old 07-19-2011, 03:27 PM
  #2584
Lighter than a ball-diff. That is impressive. And with the additional O-ring, it should be leak-less. Any experiences with the diff so far?
I really am jealous - I wish we had those for the 417's!
Nilks is offline
Old 07-19-2011, 05:06 PM
  #2585
PDR TOO's Avatar
Trader Rating: 24 (100%+)
Romauld31,
I am new to the T3 '11.
I notice you are only using one quick roll centre adjuster at the front and rear of your chassis. Is this a common set-up or something specific for your track?
PDR TOO is offline
Old 07-19-2011, 06:22 PM
  #2586
RobS's Avatar
Originally Posted by PDR TOO
Romauld31,
Its just the angle that the pictures are taken that makes them look different. Both are the quick roll center adjusters...
RobS is offline
Old 07-19-2011, 09:48 PM
  #2587
PDR TOO's Avatar
Thank you. Now that you have pointed that out I can see it.
I think my excuse is that I had a birthday on the weekend so my eyes are a year older
PDR TOO is offline
Old 07-19-2011, 10:04 PM
  #2588
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
is that with diff oil in it or without for the xray diff?
rx7ttlm is offline
Old 07-19-2011, 10:49 PM
  #2589
Hello from France,
yes, it's with the same grease in the XRay or SpecR dif.
Filled with FG grease (around 400.000 cps).
10 grams lighter!!!!
Au revoir.
Old 07-20-2011, 05:32 AM
  #2590
Xpress's Avatar
Originally Posted by romuald31
Hello from France,
Au revoir.
Do you have any idea how much lighter the spec-r is with their aluminum outdrives?
Xpress is offline
Old 07-20-2011, 09:09 AM
  #2591
Skiddins's Avatar
Probably about the same as the Xray gear diff, as far as I can see the outdrives are the only real difference with regard to weight of the diffs
Skiddins
Skiddins is offline
Old 07-20-2011, 01:51 PM
  #2592
RC MARKET's Avatar
Hello from France,
The spool:
The ball dif:
The SpecR gear dif:
The XRay gear dif:
Au revoir.
nice pics !
RC MARKET is offline
Old 07-20-2011, 02:06 PM
  #2593
Hi,
I made a chart of what gear ratios will actually fit when using 64dp. Don't know if there's one already on the net ? I know skiddins has done a 48dp. All Yellow one's will fit, Red I havent tried as I don't have the pinion or spur. I hope all the ratios are right :P let me know if any are wrong.
S.A.W is offline
Old 07-20-2011, 02:08 PM
  #2594
Tron's Avatar
Trader Rating: 17 (100%+)
Hello~
I need to work on getting my car to rotate more on corner entry and exit with a bit more on power steering. With Solaris Hard spec tires my car rotates OK, but I raced with the Solaris SP40 and the rear end seems to be more stuck, same track same setup as posted below.
I attached my setup sheet...I was thinking a 0.3mm or 0.5mm spacer under the rear suspension blocks or using the inside hole on the clamps to make a longer camber link in the rear.
For the T3 2011, which way do Ackermann spacers work? Less shims = more rotation? I'm running 1mm Ackerman spacers.
Tron is offline
Old 07-20-2011, 03:21 PM
  #2595
hana166's Avatar
hana166 is offline
