Old 07-05-2011, 11:12 PM   #2506
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
Originally Posted by Dali View Post
Hi guys
I tried adjusting the wheelbase on my t3'11. According to the T3 setup manual there is at least 5mm of wheelbase adjustment available.
I tried to follow the table (below) from the manual to achieve a wheelbase of 256mm.
From what it says I am supposed to use:
1x 1mm shim on the front of the rear arm
2x 2mm on the rear of the arm
However, when I do this there is simply no room for the rear suspension holder to screw into the rear suspension block, it is pushed to far out to screw in.
It seems that I can only adjust the wheelbase by about 3mm... is this true for the T3'11?.... the setup book suggests otherwise.
according to the T3 manual i have, page 10 says to use 2mm shim on the front and 1mm shim on the rear of the rear arm..
-Mark
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 07-06-2011, 01:02 AM   #2507
Fred Hubbard's Avatar
Hi guys
5mm is correct as the manual states...2 mm total for the front and 3mm total for the rear equals 5mm. Albeit the wheelbase adjustments can transform the car please don't forget about the plethora of other adjustments the car provides us with
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
Old 07-06-2011, 05:29 AM   #2508
Dali's Avatar
Thanks for the responses so far guys...
-Mark
Yep - My T3 manual also says that, but I was looking at the T3 setup book, which is where that screenshot is from - I don' think there is a specific setup book for the T3'11?
Yeah I wanted to adjust the wheelbase so that I could get one of my bodies to fit. The wheelbase was waay out. I'm looking forward to trying out all the other settings.
In the end I was only able to to add 3mm of shims to the rear arm and 0mm to the front rear arm.... this made the body shell (wb: 256/257mm) fit well.
Xray T3 2011, Tekin RS Pro with 13.5 Redline (Brushless), SAVOX 1251 Servo, Team Orion 5400 Carbon LiPo, Sanwa Exzes-X Radio System
Dali is offline   Reply With Quote
Old 07-06-2011, 11:01 AM   #2509
casino57's Avatar
Originally Posted by Lycan View Post
Looks to me like an incorrect servo horn. U used the one that came with the kit?
What about moving the servo holders to the other hole? I can see an unused hole in the chassis to the right of the servo. Is there one on the right hand side also?
My T3 came with a set screw for the servo. You use a ball end like what is used for the shock bottom. No screw head to get in the way then.
Mike Garcia - RCAmerica - XRay T3
Trinity - JDR - Hudy - KoPropo America
Laser Products - Tekin
Leisure Hours Raceway & Hobby Shop
casino57 is offline   Reply With Quote
Old 07-06-2011, 11:29 AM   #2510
Here you go guys
Old 07-06-2011, 01:52 PM   #2511
syndr0me's Avatar
Trader Rating: 32 (100%+)
I need two of those right this very second.
syndr0me is offline   Reply With Quote
Old 07-06-2011, 05:27 PM   #2512
Skiddins's Avatar
Yoiu might want to cut the wheelarches for the bodyshell instead of adjusting the wheelbase.
The car setup should come first, then the body. What car was the body on before if it is so far out now?
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-06-2011, 10:20 PM   #2513
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
Skiddins
Yea I definintly wouldn't change ur wheelbase just to get a body wheel archers to fit right because that is a major adjustment. U could cut the archers more or if it's too far off just mount a new body. Not worth changing the car completely just to make a body fit. Just my .02
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 07-06-2011, 11:15 PM   #2514
tazfam2's Avatar
Trader Rating: 40 (100%+)
anyone have a good setup for a high traction big track for the 11 I cant seem to get mine to run like my 10 To much steering and the back likes to kick out some times Running 17.5 open speedo. Any help would be appreciated thanks
tazfam2 is offline   Reply With Quote
Old 07-07-2011, 03:12 AM   #2515
Hey guys a bit of help would be great.
I'm picking up a t3 11 in a day.
would love to know any advice prior to build.
and any set up would be great. to be me going. thanks in advance.
this will be my first xray. going to the dark side lol
cyrrus is offline   Reply With Quote
Old 07-07-2011, 03:19 AM   #2516
CraigM's Avatar
Trader Rating: 34 (100%+)
asphalt or carpet?
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 07-07-2011, 06:32 AM   #2517
Skiddins's Avatar
What surface and what tyres?
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 07-07-2011, 06:35 AM   #2518
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Excellent guide. http://rsb.se/arena/showthread.php?t=58925
Build per kit setup. You'll be in the ballpark no matter if you are on carpet or asphalt....
Have fun building dude and take your time!!
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 07-07-2011, 07:54 AM   #2519
rcfiend's Avatar
Trader Rating: 30 (100%+)
Here you go guys
Very nice!
rcfiend is offline   Reply With Quote
Old 07-07-2011, 08:47 AM   #2520
Dali's Avatar
When you start bench testing don't be too alarmed if you hear grinding/vibrations when applying full steering lock, its the front drive shafts.
Do check to make sure the nothing is in the way of the belt as always with any build.
To remove the noise you'll want to upgrade to ESC drive shafts or limit your steering rate:
+ YouTube Video
I spent countless hours trying to work out why I was getting the noise!
