Like Tree2Likes
Xray T3 2011
Old 06-29-2011, 01:38 PM
  #2476
any idea where we can buy one?
leecampbell1 is offline
  #2477
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Skiddins View Post
The external view;
Been waiting for these for ever! lol. Now we just need 1100, 1200, 1300, 1500 CST oils...
rx7ttlm is offline
Old 06-29-2011, 01:40 PM
  #2478
Dane's Avatar
Trader Rating: 26 (100%+)
The external view;
How many limbs for this one?
Dane is offline
Old 06-29-2011, 02:03 PM
  #2479
Skiddins's Avatar
lol!!!! You'll be wanting these then;
Spec-R have released a range of high quality, temperature resistant, Gear Diff silicone oils. Easily fine tune the Spec-R, or other brand, Gear diff in your EP touring car with this range, which comes in 800, 1000, 1200, 1300, 2000, 3000, 100000 & 300000 weights.
Skiddins is offline
Old 06-29-2011, 02:06 PM
  #2480
Skiddins's Avatar
Lee, I emailed Kev last week and said as soon as they arrive I'll take one.
Skiddins
P.S. my spare Spec-R diff may be up for sale soon!
Skiddins is offline
Old 06-29-2011, 03:28 PM
  #2481
MeBeMikey's Avatar
I just ran tonight with the screws all in the topdeck and the steering ones out. Man how that makes the car handle well. I use to run one set of screws out on rear and steering post connected to top deck. The car seems more forgiving and just felt smoother pulling out of the corners and much quicker!
Thanks for the set-ups guys. I cannot wait to go to Ardent now to lay down some fast laps.
I also owe a lot of it to my LRP SS v2 speed controller!
Last edited by MeBeMikey; 06-29-2011 at 03:30 PM. Reason: I had to tell you about the speed controller!
MeBeMikey is offline
Old 06-29-2011, 03:56 PM
  #2482
Originally Posted by blade072 View Post
did you put the 2mm spacers between the servo post and the servo???.....see how you go...you should have ample clearance for the antenna mount now
i took a pic showing the problem:
help .
dcho87 is offline
Old 06-29-2011, 05:20 PM
  #2483
rx7ttlm's Avatar
I will be wanting xray oils :P lol
rx7ttlm is offline
Old 06-29-2011, 06:38 PM
  #2484
help .
You can try using Xray # 302652 for the servo horn, you will be able to eliminate the screw therefore moving closer to top deck.
flken is offline
Old 06-29-2011, 08:51 PM
  #2485
andrewdoherty's Avatar
Trader Rating: 48 (100%+)
I think the real issue is the servo. I think the mounting tabs are just in a funky location relative to other servos. I had the same issue and it was solved by using their 9550 look-alike servo.
andrewdoherty is offline
Old 06-29-2011, 09:21 PM
  #2486
I see what your saying, that does look like the problem.
flken is offline
Old 06-30-2011, 01:09 AM
  #2487
CraigM's Avatar
Trader Rating: 34 (100%+)
help .
As long as you can get the angle of the steering arm right and have clearance then I wouldn't worry too much about how many spacers you need to use. As for the antenna, you can either just find another hole to mount it or you could use double sided tape under the servo instead of the rear servo mount.
CraigM is offline
Old 06-30-2011, 02:41 AM
  #2488
spring71's Avatar
Smile
More T3 parts,Spec R T2 and T3 gear diffs and Spec R Differential Oils are in stock.
Click Here to check out the new arrivals.
Click Here to see the Xray parts store
Thanks.
spring71 is offline
Old 06-30-2011, 04:33 AM
  #2489
nitrobeast's Avatar
Trader Rating: 46 (100%+)
Default t3 diff
Anybody see a price yet?
nitrobeast is offline
Old 06-30-2011, 05:44 AM
  #2490
Dane's Avatar
help .
Use this where the linkage connects to the horn. http://www.nexusracing.com/product_i...roducts_id=764
Dane is offline
