Like Tree2Likes
Xray T3 2011
Old 06-16-2011, 05:32 AM
  #2431
Skiddins's Avatar
Originally Posted by S.A.W View Post
Hi,
For all the top/good drivers that drive at a variety of tracks do you have a base set up for asphalt and carpet that you will always start with ? do you use the T3'11 Basic Set Up or have your own one, or do you use your set up from the last track ?
Thanks.
Maybe I'm not good enough to answer but....
I have a 'default' setup for my local track which I will always start with when going somewhere else. After I have a setup for the new track I will start with that back at my local track to see how it compares.
Skiddins
Skiddins is offline
Old 06-16-2011, 05:34 AM
  #2432
blade072's Avatar
Trader Rating: 98 (100%+)
Originally Posted by romuald31 View Post
Hello from France,
here's my T3-11 with the servo in the right way !!!
No extra parts needeed... Only with the parts out of the box!!
The servo is double sided and, after more than 15 packs, no problems.
Au revoir.
i might try this also...awesome pics....thanks mate
blade072 is offline
Old 06-16-2011, 04:36 PM
  #2433
JamesReilly's Avatar
Trader Rating: 59 (100%+)
[QUOTE=romuald31;9259910]Hello from France,
Very nice set up. If I may make a suggestion, I believe your steering link from the servo to the steering rack is too short, I did this the first time I turned the servo and it makes the car nervous and twitchy. If you lengthen the link to the other side of the rack you will like it a lot more, it made the steering much smoother and more linear.
JamesReilly is offline
Old 06-17-2011, 01:47 AM
  #2434
John_S's Avatar
Thanks.
So what does the shim under the rear shock do ? I run one on the front.
How will a car drive/feel with 0.5 front toe compared to 1.0 ?
The setup sheet is a little sketchy as far as shock shims go. I run 1mm on the wishbone on the frot and 1mm on the shock tower on the rear just to bring he shocks back to the same angle as kit. This is required because of the wheelbase change.
I can't help you for toe in as I always just run 1 degree toe out.
John_S is offline
Old 06-17-2011, 05:15 AM
  #2435
Dane's Avatar
Trader Rating: 26 (100%+)
Shim under the shock doesn't make a huge difference.
1.0 gives more steering entry and stability. Pretty much standard among most setups.
Dane is offline
Old 06-19-2011, 01:20 AM
  #2436
Default new adjustable bulkheads
ran my t3 for the first time yesterday, really impressed with pretty much everything!
was looking at the new adjustable bulkheads, i run pretty much solely on high grip carpet with rubbers, how much difference will they potentially make to the standard setup? i'm only about 0.15 - 0.2 secs a lap off the very top boys so am looking for just a little improvement??
Mb3195 is offline
Old 06-19-2011, 09:36 AM
  #2437
Originally Posted by CraigM View Post
Have you tried different goop? I find Rhienard only works on a few tracks, and it can make the car really squirrelly everywhere else.
I would stand the rear shocks back up to kit and go to 2 deg of rear camber to settle the rear down, then go back to 3.0 or 2.8 front spring to get the front end back, and put the shocks back down a hole on the tower. To get better initial you can go back to 1mm shim on the C-hub or add a bit of antidive, 0.5mm shim under the suspension block behind the spool is a good way to achieve this.
Tried these settings today and also put rear droop from 5 to 4 and 2deg camber on the front. Also put the L's back on all round. Didn't try the shim under the suspension block though. Car felt good and knocked over a second off my pb, it will go quicker but it's just down to my driving now and hitting the corners right.
S.A.W is offline
Old 06-19-2011, 10:41 AM
  #2438
defcone's Avatar
Trader Rating: 15 (100%+)
Apparently the S411 gear diff fits in the t3, you just need to shim it a tiny bit and run tamiya dogbones with matching boneblades.
defcone is offline
Old 06-19-2011, 08:53 PM
  #2439
CraigM's Avatar
Trader Rating: 34 (100%+)
Nice!
CraigM is offline
Old 06-20-2011, 01:12 AM
  #2440
over gear's Avatar
Trader Rating: 17 (100%+)
Default Servo saver
I found the T3'11 servo saver too soft compare to the tamiya servo saver... any suggestion on how to stiffen it up? and yes, the springs are installed correctly
over gear is offline
Old 06-20-2011, 03:46 AM
  #2441
Trader Rating: 16 (100%+)
do you need 50mm cv shafts in front to put gear diff or just rear
jay m is offline
Old 06-20-2011, 06:28 AM
  #2442
Default diff in front
52mm will fit fine. I've actually got some schumacher ones with the holes drilled to make the pins fit. They dont chatter as much as the xray ones do.
Mb3195 is offline
Old 06-21-2011, 02:50 PM
  #2443
haywood's Avatar
Trader Rating: 49 (100%+)
Default Shock Tool
How many of you guys use this tool?
Low Price: $11.99
This item earns up to 12
Customer Rewards Points!
In Stock!
Free Shipping Eligible!
(See Details)This is the Hudy Shock Absorber Assembly Tool. This unique tool in the line of HUDY Professional Tools is the perfect tools for assembling XRAY or Serpent shock absorbers. The tool has two tabs that fit precisely into the grooves in the bottom nylon shock cap. Use the tool to help you push and twist the cap onto the shock body...simple! Made from lightweight, hardcoated duraluminum for durability and long life.
Features
Special tool for assembling XRAY and Serpent shock absorbers
Lightweight, hardcoated duraluminum
High quality and long life
haywood is offline
Old 06-21-2011, 03:02 PM
  #2444
i bought one. its helpful but not necessary, so long as you can get the end cap off.
J.Lee is offline
Old 06-22-2011, 07:59 AM
  #2445
M-Technic's Avatar
I use it.
M-Technic is offline
