Xray T3 2011
#2416
#2418
So if flipping the L spacers is between H and L, then a 0.5mm spacer may get you right there.
#2419
Can you double check that info EA? R1 and F1 with 0mm spacers under the ball are equivalent to L roll centers and R1 and F1 with 1mm spacer under the ball is equivalent to H roll centers.
EA
#2421
The clamps need to be redesigned to offer a full range of adjustability. As the cars get lighter and faster guys will be looking for more camber gain.
#2425
Hello from France,
here's my T3-11 with the servo in the right way !!!
No extra parts needeed... Only with the parts out of the box!!
The servo is double sided and, after more than 15 packs, no problems.
Au revoir.
Au revoir.
#2426
Hi,
For all the top/good drivers that drive at a variety of tracks do you have a base set up for asphalt and carpet that you will always start with ? do you use the T3'11 Basic Set Up or have your own one, or do you use your set up from the last track ?
Thanks.
Thanks.
#2427
The setup is only as good as the build. Many drivers search for a setup that works with the impediments built into the car. A well built car will utilize a variety of setups and be fast. In other words if you put more time into the build of the car you will have an easier time finding a setup that works for you. Good luck!
#2428
I have a base set up that I normally start with and then make changes from there to suit the track. I've used my car on a number of tracks now so normally when I go to a new track I have an idea of what changes I'm expecting to make ahead of time, then I make them one by one. I rarely set my car up ahead of time because I prefer to know what effect each change has.
#2429
Alright m8 my setup on the Xray website from brca rd2 is what I use when I go to a new track. The main changes would be ride height, bodyshell and some other small things. My name on the Xray website is also John_s
#2430
So what does the shim under the rear shock do ? I run one on the front.
How will a car drive/feel with 0.5 front toe compared to 1.0 ?
