Like Tree2Likes
Xray T3 2011
Old 06-04-2011, 07:23 PM
  #2281
Here is how i fitted my electronics.
dex410usa is offline
Old 06-04-2011, 08:20 PM
  #2282
Slideaway's Avatar
Well done.
Slideaway is offline
Old 06-04-2011, 10:48 PM
  #2283
rack's Avatar
Trader Rating: 68 (100%+)
I put my T3 11 together and took it to the track. My car is all stock the car turns good to the right but spins out half way in the turn to the left. I took apart the front end and checked it all it all looked good. I made sure that it turned equally to the right and left but the car still spins out to the left. I heed help.
rack is offline
Old 06-04-2011, 10:59 PM
  #2284
Trader Rating: 31 (100%+)
Ronny,
When I see you next I will have a look at it.No worries.
racenut123 is offline
Old 06-04-2011, 11:09 PM
  #2285
rack's Avatar
Originally Posted by racenut123 View Post
Ronny,
thanks this car is giving me the blues.
rack is offline
Old 06-05-2011, 12:08 AM
  #2286
Don't worry. It's probably a little oversight. It happens. Most t3 2011 I have driven are super dialed.
Old 06-05-2011, 12:15 AM
  #2287
rack's Avatar
when is the next time you are going to be at norcal
rack is offline
Old 06-05-2011, 01:17 AM
  #2288
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by rcfiend View Post
Anyone know where you can buy the Tamiya black shocks and are they a direct fit for the Xray springs or do you have to run the Tamiya springs?
http://www.rctech.net/forum/electric...ml#post9210912
The xray springs fit but are a touch big for the retainer. It's best to use the xray top and bottom, that lets you use the xray retainer
CraigM is offline
Old 06-05-2011, 08:07 AM
  #2289
rcfiend's Avatar
Trader Rating: 40 (100%+)
Thanks CraigM.
rcfiend is offline
Old 06-05-2011, 10:10 AM
  #2290
mok
mok's Avatar
i have been running on asphalt with a spool in the front, gear diff in the back..
i'm curious to know how many ppl are getting what appears to be 2 times the tyre wear on their front tyres vs the rears with this chassis?
what have ppl done to balance out tyre wear front to back?
(my preference is to not rotate tyres front->back..)
is it a side effect of running the spool?
would a tight ball diff or gear diff be better?
just looking for some options..
-Mark
mok is offline
Old 06-05-2011, 10:46 AM
  #2291
StevenOlsen's Avatar
-Mark
im running a geardiff in the front with 500.000 cst kyosho oil. and that seems to even out the tirewear.
StevenOlsen is offline
Old 06-05-2011, 12:31 PM
  #2292
Chris Adams's Avatar
-Mark
All cars wear the fronts out slightly faster than the rear. I would def look over your setup. Usually a car that wears out the fronts a lot faster is one that is pushing through the corners.
Chris Adams is offline
Old 06-05-2011, 01:22 PM
  #2293
John_S's Avatar
I agree with chris that a car with some understeer will wear the tyres out extremely quickly. Post you setup so we can have a look and try and diagnose the issue
John_S is offline
Old 06-05-2011, 01:28 PM
  #2294
My fronts always seem to wear alot faster and my car does push, so I like to see some setup's tips to get more even wear and less push.
S.A.W is offline
Old 06-05-2011, 01:36 PM
  #2295
I like to think of everything in a few different ways. Tire contact and weight transfer. If your not getting enough tire contact the car isn't going to work to the best of its ability no matter how good of a driver you may be. The weight transfer issue is how much weight is being "thrown" to the front of the car and how fast is that weight going there. If it goes too fast and stays too long, the car will push and possibly throw the rear of the car around. If it doesn't transfer enough, the car also will have a hard time turning.
Keeping that in mind, there is also a difference between steering and rotation.
