Like Tree2Likes
Xray T3 2011
Old 05-08-2011, 09:24 PM
  #2116
Originally Posted by rcfiend View Post
What spur gear are you guys running for 17.5 non boost?
92..64P
light is offline
Old 05-08-2011, 09:28 PM
  #2117
rcfiend's Avatar
Trader Rating: 40 (100%+)
Originally Posted by light View Post
92..64P
How are you adjusting the rear motor screw?
rcfiend is offline
Old 05-08-2011, 09:42 PM
  #2118
Tron's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Fred Hubbard View Post
To add to that, the car will change direction faster which is really apparent on tracks with chicanes. Since our asphalt and carpet tracks over here in the U.S. tend to have more grip than Euro style tracks we pretty much run them 99% of the time, 50mm driveshafts that is.
Hi Fred, do the ECS driveshafts wear out and require complete replacement or are the wear parts easily purchased at a cheaper rate?
Is 50mm what you use with the NT1 gear different too?
Tron is offline
Old 05-08-2011, 10:10 PM
  #2119
rcfiend's Avatar
Here is what I see when trying to adjust the rear motor screw. The button head screw will not fit through the the large hole on the 96 spur gear and I don't have enough room to insert the driver to adjsut the rear screw either.
Am I missing something?
rcfiend is offline
Old 05-08-2011, 10:15 PM
  #2120
303slowdown's Avatar
Trader Rating: 24 (100%+)
i tighten the front screw then pull the top deck and lift the spur out and then put in and tighten the rear screw its a pain but it works
303slowdown is offline
Old 05-08-2011, 10:24 PM
  #2121
rcfiend's Avatar
Ok, I figured it was something like that. It's clear the car was designed for mod racing. Their spur gears have larger holes and allows them to adjust that rear screw.
rcfiend is offline
Old 05-08-2011, 10:51 PM
  #2122
Fred Hubbard's Avatar
Hey Brett, eventually the parts do wear but of course wear is a function of how much power is run in the car. Even in mod I don't replace parts that often. Yep all the parts can be purchased separately. With all the current gear diffs available we have to run 50mm shafts...for the moment.
Fred Hubbard is offline
Old 05-09-2011, 04:38 AM
  #2123
Team EAM
Trader Rating: 79 (100%+)
Our you can open that one hole up with a reamer or drill. Just go in and make the opposite hole the same size to keep it balanced. This is what I have done in the past. Your taking so little material off you probably dont really even need to do the opposite hole but I did anyway.
EA
EAMotorsports is offline
Old 05-09-2011, 05:48 AM
  #2124
ChrisP's Avatar
I've simply gone to using a 2.0mm ball end driver for the rear motor screw.
ChrisP is offline
Old 05-09-2011, 05:56 AM
  #2125
M-Technic's Avatar
Trader Rating: 15 (100%+)
17.5 non-boost (or VTA) is probably the only class that would have problems. I run 17.5 boosted with a 114 spur and no problems at all.
M-Technic is offline
Old 05-09-2011, 07:12 AM
  #2126
rcfiend's Avatar
EA
EA thanks for your suggestion. I was thinking of doing the same thing.
rcfiend is offline
Old 05-09-2011, 07:13 AM
  #2127
rcfiend's Avatar
Not sure how this helped, unless the 2.0 screw is smaller. What size is the screw?
rcfiend is offline
Old 05-09-2011, 08:15 AM
  #2128
M-Technic's Avatar
He means using a 2.0mm wrench that has a ball tip instead of straight. It allows you to use the wrench at an angle.
Old 05-09-2011, 08:25 AM
  #2129
rcfiend's Avatar
Ok, I understand now. That's another great option. Thanks for the feedback everyone. Looking forward to putting some laps on the new car!
rcfiend is offline
  #2130
M-Technic's Avatar
Does anybody have a good source for ceramic diff balls and thrust bearings for the Xray diff? Within the United States, preferably.
The diff balls are 2.4mm and the thrust is 3x8x3.5mm.
Thanks!
