Old 05-08-2011, 11:23 AM   #2101
Magnet Top's Avatar
Originally Posted by jammincrtjames View Post
....Low profile shock bladders .....I keep getting a hole in the middle of the bladder after 5 or 6 runs.
+1
Magnet Top is offline   Reply With Quote
Old 05-08-2011, 11:52 AM   #2102
Korey Harbke's Avatar
I had my original set split because I'm a he-man on the shock caps when tightening them down, but I've never had a hole appear.
Like Skuba Steve had mentioned, the HB or Tamiya bladders work really well. I just take a dremel with a sanding drum and lightly sand/shave the edges slightly. They are a lot thicker and stiffer too, so you'll get a little more pack (thats good). They are also even more low profile and give the overall shock assembly greater oil capacity.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-08-2011, 11:59 AM   #2103
haywood's Avatar
Trader Rating: 49 (100%+)
Default Lap Times
I have my 2011 ready and will have limited track time before our first series race and was wondering on carpet if I went out and ran it with a rear ball diff and then switched to a gear diff do you think i would see a differance in lap times? Anyone have any input on this? Thanks
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 05-08-2011, 12:04 PM   #2104
Depending on the level of grip on the track, and what fluid you put in the gear diff will dramatically affect how the car feels in comparison to a ball diff. I prefer gear diffs on higher grip tracks, and ball diffs on lower grip. The ball diffs are a little easier to drive, but I think the gear diff will produce the fastest lap time if setup and driven correctly.
You'll just have to try it and see for yourself! Start with 1000wt oil and go from there
-Korey
Old 05-08-2011, 01:05 PM   #2105
The Evicerator
Thanks Steve. How do you shave the out site edges? I have problems with the bladders as well?
I just take a dremel with a sanding drum and gently work my way around the outside edge... it's hard to measure so it's basically just a matter of taking off material a small bit at a time and test fitting them on the shocks until it's comfortable to build properly.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 05-08-2011, 01:44 PM   #2106
rcfiend's Avatar
Trader Rating: 30 (100%+)
I'm running 17.5 with my T311 and I'm using the Xray 96 spur and I can't get the rear motor screw through the spur gear to adjust gear mesh. Are you guys enlarging the wholes in the spur gear to get the motor screw (button head) to go through the spur gear?
rcfiend is offline   Reply With Quote
Old 05-08-2011, 01:59 PM   #2107
Monkeys punk's Avatar
Mine fits fine.
Silly question but you are trying to get it through the bigger hole as the kit spur has 2 different sized holes around it.
Monkeys punk is offline   Reply With Quote
Old 05-08-2011, 02:00 PM   #2108
rcfiend's Avatar
What spur gear are you guys running for 17.5 non boost?
Old 05-08-2011, 02:15 PM   #2109
rcfiend's Avatar
Originally Posted by Monkeys punk View Post
Mine fits fine.
I'm not using the kit spur. The kit spur is 48 pitch and I run 64 pitch. I'm using the Xray 96, 64 pitch spur gear for 17.5 non-boost. What spur gear are using. And yes I am trying to use the larger hole on the spur gear.
Old 05-08-2011, 02:30 PM   #2110
jetboy3's Avatar
Trader Rating: 21 (96%+)
g day, iv just purchased a t3 11 and will be running in a 21.5 turn no boost class. problem is i cant seam to find a spur pinion combo to get me close to the 3.5 ratio mark and what will fit. any help would be appreciated.
jetboy3 is offline   Reply With Quote
Old 05-08-2011, 02:37 PM   #2111
Ebay.co.uk and search RW racing i think he is called , you need about a 72 spur with a 36 pinion (i think)
sidecarphil1 is offline   Reply With Quote
Old 05-08-2011, 06:03 PM   #2112
Chris08527's Avatar
Trader Rating: 16 (100%+)
double post sorry . ..
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 05-08-2011, 06:03 PM   #2113
Chris08527's Avatar
Hello,
i was looking at doing the new bulkhead clamps with the roll center adjusters part # 302028-0 mod, however not 100% sure on the part #'s for the ball cups with the hole in the top to access the ball end, the ball ends or the turnbuckles any help would be great,
thanks
Chris
Old 05-08-2011, 06:45 PM   #2114
Team Speedy's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Chris08527 View Post
Hello,
thanks
Chris
Hey Chris,
Give this a shot:
  • 302665 - opened ball joint, allows the ability to use a 2mm Ball/Allen to remove from the C-Hub for easier disassemble or roll center adjustment. [set of 4]
  • 302660 - Closed ball joints, set of 4
  • The following below is sold as a pair, choose your desired height and add the amount desired.
  • 302653 (6mm) ** Set of 2 - Standard size
  • 302654 (8mm) ** See above
  • 302655 (10mm) ** See above
Best of luck!
RcAmerica | Xray | Hudy |
Team Speedy is offline   Reply With Quote
Old 05-08-2011, 10:21 PM   #2115
88..
Jackson RC Raceway, Home of the 2011 Paved On Road Nats!
Horsham RC Raceway,Home of the 2013 and 2015 Carpet On Road Nats!
Awesomatix USA/ Side Piece Racing / TQ Wire / CR Graphics / R1 Wurks / LRP /Jackson RC Raceway / Horsham RC Raceway/Brownies Hobbies
Al Sodano is offline   Reply With Quote
