Like Tree2Likes
Xray T3 2011
Old 05-06-2011, 09:45 PM
  #2086
Korey Harbke's Avatar
Originally Posted by Fred Hubbard View Post
I run 64mm on both surfaces. The kit setup with a few tweaks should be a good place to start with for stock class racing, the main options I would add would be a gear diff (1000cSt Oil) for the rear and 50mm driveshafts all around. Actually it's just the opposite, making the shock longer will generate less pack which in turn will yield less traction.
+1
Yea what he said :P
-Korey
Korey Harbke is offline
Old 05-06-2011, 10:51 PM
  #2087
Benzaah's Avatar
Trader Rating: 24 (96%+)
Originally Posted by hacker View Post
oh sorry, I meant front uprights!
my post was a little misleading as I was talking about the rear changes, and then also mentioned the uprights....I call the rears, hubs anyway, but it's all good If anything I'd like to run more than 4mm washers under the rear hubs, but wheel clearance issues wont allow me, so its lowering the inner rear camber links it will be instead.
If you get the option 10 mm ball studs and run the kit rod ends you can fit 5mm easily. I have 4.5 on my rear end and it sticks like melted butter to toast.
Benzaah is offline
Old 05-06-2011, 11:11 PM
  #2088
Fred Hubbard's Avatar
Originally Posted by 4RacerX View Post
Thanks for the information and response Fred.
Fred Hubbard is offline
Old 05-06-2011, 11:12 PM
  #2089
Originally Posted by Korey Harbke View Post
+1
Yea what he said :P
-Korey
See ya soon
Old 05-07-2011, 09:57 AM
  #2090
John_S's Avatar
What is the advantage of going to 50mm driveshafts in the front?
John_S is offline
Old 05-07-2011, 10:11 AM
  #2091
more steering less stable then running 52mm shafts
mwoods is offline
Old 05-07-2011, 10:43 AM
  #2092
To add to that, the car will change direction faster which is really apparent on tracks with chicanes. Since our asphalt and carpet tracks over here in the U.S. tend to have more grip than Euro style tracks we pretty much run them 99% of the time, 50mm driveshafts that is.
Old 05-07-2011, 12:18 PM
  #2093
haywood's Avatar
Trader Rating: 49 (100%+)
Fred, Are you running the 50mm ecs in the front? Is it worth the money to upgrade to the ecs setup? Thanks
haywood is offline
Old 05-07-2011, 12:22 PM
  #2094
Yep, Definitely!
Old 05-07-2011, 01:17 PM
  #2095
Could someone please explain this me. I fail to see how, when you are physically on your max lock, (steering hub butted up-tight against the c-hub), 50mm front driveshafts can give you more steering than 52mm driveshafts.
RSCosworth is offline
Old 05-07-2011, 04:35 PM
  #2096
rcfiend's Avatar
Trader Rating: 40 (100%+)
On page 17 of the manual, camber link assembly, it tells you to assemble L1-L2 to the ball cup with the molded dot facing the inside of the L1-L2. If you were to do this it would be on the smaller opening of the ball cup causing binding. Just checking to see If the manual is incorrect before I possibly ruin the ball cups.
rcfiend is offline
  #2097
The Evicerator
When under power the drive shafts bind in the diff outdrives a bit and have a tendancy to want to impart a torque that forces the suspension to flatten out a bit... A longer drive shaft tends to bind more, impart torque, and resist roll more... In essence limiting roll somewhat like a roll bar.
Steve Weiss is offline
Old 05-08-2011, 08:13 AM
  #2098
jammincrtjames's Avatar
Does anybody know if there are other Low profile shock bladders that fit the Xray shocks? I keep getting a hole in the middle of the bladder after 5 or 6 runs.
jammincrtjames is offline
Old 05-08-2011, 09:39 AM
  #2099
The Evicerator
Bladders from Tamiya and Hot Bodies will fit the Xray shocks ... I would recommend shaving the outside edges of them so that they fit inside the Xray threaded caps for easier building/bleeding
Old 05-08-2011, 10:11 AM
  #2100
Thanks Steve. How do you shave the out site edges? I have problems with the bladders as well?
