Like Tree2Likes
Xray T3 2011
Old 05-05-2011, 11:37 PM
  #2071
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by sidecarphil1
Yeah i tried it with the 1.15mm spacers and you can use the 52mm shafts but you have to cut down the blades a lot , this makes them weeker and in Mod it is not strong enough , stock is ok though
A liked the diff up front with 300,000 oil in it but it was slower so i took it out again
Thanks for the response. I saw Hagberg uses cleaning gum in his so I was considering either using that or 500k.
CraigM is offline
Old 05-06-2011, 03:58 AM
  #2072
hacker's Avatar
Trader Rating: 141 (100%+)
Originally Posted by CraigM
kit should be 4mm on the rear uprights, 2x2mm shims
http://www.teamxray.com/teamxray/sho...p?file_id=7076
oh sorry, I meant front uprights!
my post was a little misleading as I was talking about the rear changes, and then also mentioned the uprights....I call the rears, hubs anyway, but it's all good If anything I'd like to run more than 4mm washers under the rear hubs, but wheel clearance issues wont allow me, so its lowering the inner rear camber links it will be instead.
hacker is offline
Old 05-06-2011, 12:30 PM
  #2073
I was waiting for Xray come out with a gear diff but it seem as if they are not going to, should I go ahead and get the spec-R diff? is there any problems with the spec-r? like leaking or anything else? thanks.
gofasteddy is offline
Old 05-06-2011, 12:40 PM
  #2074
there is a xray geared diff coming soon but dont no wen , i use a spec-r diff without any probs not leaking wat so ever..
mwoods is offline
Old 05-06-2011, 12:41 PM
  #2075
Xpress's Avatar
Yes and.......yes!
Xpress is offline
Old 05-06-2011, 01:01 PM
  #2076
Thanks guys.
Old 05-06-2011, 05:57 PM
  #2077
What shock length is everyone using? Also is the kit setup a good place to start on high bite asphalt?
4RacerX is offline
Old 05-06-2011, 06:01 PM
  #2078
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
I always run 63 mm.
andrewdoherty is offline
Old 05-06-2011, 06:04 PM
  #2079
Originally Posted by andrewdoherty
I always run 63 mm.
Is that shock length for asphalt? Any suggestions for starting setup on asphalt high bite?
4RacerX is offline
Old 05-06-2011, 07:31 PM
  #2080
I run that length for carpet and asphalt. I'd check to see what Hubbard was running at West Coast; thats about as high bite as I can imagine for asphalt. There might be a set up on the XRay forums...
Old 05-06-2011, 07:37 PM
  #2081
Ok. Thanks for the information. I'll try the 63 mm shock length. One more question, if your shock length is longer does that generate more traction?
4RacerX is offline
Old 05-06-2011, 08:35 PM
  #2082
Fred Hubbard's Avatar
I run 64mm on both surfaces. The kit setup with a few tweaks should be a good place to start with for stock class racing, the main options I would add would be a gear diff (1000cSt Oil) for the rear and 50mm driveshafts all around. Actually it's just the opposite, making the shock longer will generate less pack which in turn will yield less traction.
Fred Hubbard is offline
Old 05-06-2011, 09:04 PM
  #2083
Thanks for the information and response Fred.
4RacerX is offline
Old 05-06-2011, 10:03 PM
  #2084
rcfiend's Avatar
Trader Rating: 42 (100%+)
If you mix up the roll center blocks how do you tell them apart? Are there etchings I'm missing?
rcfiend is offline
Old 05-06-2011, 10:38 PM
  #2085
rcfiend's Avatar
Just figured out how to identify the difference.
rcfiend is offline
