Like Tree2Likes
Xray T3 2011
Old 05-04-2011, 03:43 PM
  #2041
Trader Rating: 30 (100%+)
Anyone have a good setup for rubber/asphalt, medium grip, high speed layout for the older style upper camber link setup? I dont have the new bulkhead caps yet but want a good starting point. BTW it's for 17.5 blinky. Thanks in advance!
racenut123 is offline
Old 05-04-2011, 03:56 PM
  #2042
Korey Harbke's Avatar
I bet kit setup with 500cst oil all around and the rear shock laid in a hole would be pretty solid starting point. You can adjust camber, wheelbase, and all that other junk to your liking.
-Korey
Korey Harbke is offline
Old 05-04-2011, 04:01 PM
  #2043
Thanks Korey!
BTW, nice having you down at Norcal Hobbies the last onroad race day. Didn't finish as well as I thought you could but hey, everyone has one of those days. You raced at Cap City too? Man you really take this toy car racing thing seriously!
-Korey
  #2044
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by 1101 View Post
is this fake, I'd hate to see someone get ripped off
Strange shocks, batt strap not OEM, Delrin bulkheads ??????
http://cgi.ebay.co.uk/XRAY-T3R-Premi...item2c5c71b683
Def a fake. No doubt it actually ships from China. I would report it to ebay.
MikeR is offline
Old 05-04-2011, 04:16 PM
  #2045
Thanks Korey!
Yea...
Apparently my skin got a lot darker, and I got a lot taller at Cap city. Then I got shorter and gained some weight at Norcal.
All in fun. I think it's pretty awesome my buddies down there still try to mess with me from afar
-Korey
Old 05-04-2011, 04:37 PM
  #2046
Trader Rating: 19 (100%+)
Yea...
-Korey
At least you didn't get a sunburn. LOL
Advil is offline
Old 05-04-2011, 04:45 PM
  #2047
Already have one! The sun is actually out in Washington!
Old 05-04-2011, 05:02 PM
  #2048
At the carpet nats Korey was so white you could see the blood pumping thru him. I hope he goes to the tanning salon or spray tans before he spends a week in the sun in ca.
AARON YOUNG is offline
Old 05-05-2011, 03:51 AM
  #2049
Hi,
I run the Spec R gear diff in the rear with 1000cst oil, would like to try one in the front. What oil do I need for asphalt and carpet ?
Thanks.
S.A.W is offline
Old 05-05-2011, 04:51 AM
  #2050
Originally Posted by S.A.W View Post
Hi,
Thanks.
from wat i read use 1000 for asphalt (rear) 2000 carpet. for the front run 50000...
mwoods is offline
Old 05-05-2011, 05:50 AM
  #2051
hacker's Avatar
Trader Rating: 141 (100%+)
-Korey
what else can I do besides the above? I started off with kit setup, but the car is very rear end happy, on power AND off power. It's got to be the loosest standard kit setup I have ever driven. I tried a lower rear roll center, took off the rear bar. Could it be the way I built the shocks? I have about 3/4 rebound.....next on my list of things to do, is drill a hole in the shock caps and go for 0 rebound, wider front hex's, go an extra hole in on the rear shock tower.
hacker is offline
Old 05-05-2011, 05:58 AM
  #2052
Rockin Rich's Avatar
Originally Posted by hacker View Post
what else can I do besides the above? I started off with kit setup, but the car is very rear end happy. It's got to be the loosest standard kit setup I have ever driven. I tried a lower rear roll center, took off the rear bar. Could it be the way I built the shocks? I have about 3/4 rebound.....next on my list of things to do, is drill a hole in the shock caps and go for 0 rebound, wider front hex's, go an extra hole in on the rear shock tower.
I ran Eric Anderson's set up from the Snow Birds, found on X-Rays web site, car pushed a little too much for my liking so, I went back to standard wheel hex's in front, leaned the front shocks in 1 hole and she took off. With EA's or Paulies set up you will eliminate the loose rear end!
Rockin Rich is offline
Old 05-05-2011, 06:11 AM
  #2053
Team EAM
Trader Rating: 79 (100%+)
Both Paul and my setups are a little pushy especially on lower bite tracks. As the traction comes up they usually pick up steering and are even better. Taking a little toe away from the rear also will help it turn a little more on lower bite.
EA
EAMotorsports is offline
Old 05-05-2011, 08:27 AM
  #2054
hacker's Avatar
Default rear loose
EA's Snowbird setup for carpet? I run asphalt, should it still be pushy on asphalt? I don't mind a pushy car right now.
I've just made some rear camber link changes now to inside lower, and on the setup station its proven to provide more camber gain, rear toe in to 4degree, 0 shim under uprights. I know its not a good practice to do multiple changes at once, but I just don't have enough time to test before the next race. See how she goes.......
what's the difference between these quick roll center holders?
303033, comes with kit
and
303032, optional
surely not just the color, and included ball joint?
hacker is offline
Old 05-05-2011, 09:10 AM
  #2055
and
303032, optional
Yes I was running on asphalt with the carpet s/u, except for the changes I noted.
Kit quick roll center holders allow longer chamber link, optional ones are standard length from previous generation kits, (2009 and earlier)
