Like Tree2Likes
Xray T3 2011
Old 05-02-2011, 05:12 PM
  #2026
Skiddins's Avatar
Originally Posted by ByteStream
Does anyone make ball studs that thread all the way to the top?
Secondly, what tool would you need to backcut the clamps?
That would be an M3 Tap.
I assume that there is a hole all the way through, it's just that the thread doesn't also go all the way through.
As they are alloy it should be fairly easy to tap.
Skiddins
Skiddins is offline
Old 05-02-2011, 06:39 PM
  #2027
Trader Rating: 15 (100%+)
I used top ball studs and they have long ballcups that are the same style as Xray . I think they are 5.5mm balls and are low profile .
AARON YOUNG is offline
Old 05-02-2011, 07:38 PM
  #2028
ByteStream's Avatar
Skiddins
The holes seem to be threaded all the way through, the recommended ball studs are not threaded all the way. So it seems you need to either:
1. Create more threads on the ball studs so they reach the top of the lip
or
2. Ream out the clamps so the non threaded part of the ball studs will fit. (which I believe would mean a larger diameter that an M3 tap).
Either way at somewhere around $45 a pair ... was expecting a better fit and finish to the recommended use of harware.
ByteStream is offline
Old 05-03-2011, 09:37 AM
  #2029
hacker's Avatar
Trader Rating: 141 (100%+)
Default setup book
finally got to build my first xray.
does the setup book come standard with the kits? mine doesn't have one, I only have a downloaded pdf version from xray.
hacker is offline
Old 05-03-2011, 09:54 AM
  #2030
M-Technic's Avatar
Yes, the setup book should come with all new kits.
M-Technic is offline
Old 05-03-2011, 09:57 AM
  #2031
hacker's Avatar
bummer, didn't come with mine, also I noticed the gearing chart and cheat sheets were not included too. Oh well, not too much of a drama.
hacker is offline
Old 05-03-2011, 11:25 AM
  #2032
JayBee's Avatar
Trader Rating: 31 (100%+)
WTF's up with that!!! How much did you pay for that kit?! The high gloss manual/set-up cheat sheets are all part of the 'LUXURY' package of ownership. That's BULLSHIT!! You don't have to be upset, I'll be upset for ya.......
JayBee is offline
Old 05-03-2011, 12:04 PM
  #2033
+1
sidecarphil1 is offline
Old 05-03-2011, 05:49 PM
  #2034
casino57's Avatar
My kit didn't come with one either....I have mine from the 2010 model tho. i use it quite a bit!
casino57 is offline
Old 05-03-2011, 08:04 PM
  #2035
R/C Tech Elite Member
touringdriver's Avatar
Trader Rating: 16 (100%+)
raced my t3 11 for the first time sunday, all i can say is WOW! what a major difference from the 009 sedan. also running front and rear gear diffs to. these things should of been designed years ago.
touringdriver is offline
Old 05-03-2011, 11:33 PM
  #2036
Default is this fake ??
is this fake, I'd hate to see someone get ripped off
Strange shocks, batt strap not OEM, Delrin bulkheads ??????
http://cgi.ebay.co.uk/XRAY-T3R-Premi...item2c5c71b683
1101 is offline
Old 05-04-2011, 02:10 AM
  #2037
hacker's Avatar
definitely genuine and kit was sealed, purchased from a well known US supplier.
hacker is offline
Old 05-04-2011, 03:04 AM
  #2038
100% yes. Welcome to the xray 008 China version with foam deck.
maxg123456 is offline
Old 05-04-2011, 03:58 AM
  #2039
shikakae123's Avatar
The new kit should not have the set up book.based on the XRAY rx8 manual,the thing say that to make sure all set up information is the most updated,therefore the set up book will only be available online
shikakae123 is offline
Old 05-04-2011, 03:13 PM
  #2040
ByteStream's Avatar
Well, not printing and including the glossy stuff and setup sheets saves Xray a bit of money and since the price of kits isn't going down .. I'd like to see them do something for the customer's with that savings ... like including some ECS's or aluminum shocks or new upper clamps in the 2012 edition, it would be only fair.
Maybe I'll sell my glossy setup book on eBay, since I guess it is a limited edition collectors item now .. lol.
