Xray T3 2011
#1996
anyone done any testing with the 2 hole front lower arms?
http://demonpowerproducts.co.uk/prod...oducts_id=4917
#1997
#1998
are the inner hole in the same place as the standed lower arms?
#1999
guys just want to know if the T32010 and T32011 are have the same rear bulkhead, I heard the T32011 have a better rear bulkhead how true is this?
#2002
Hi there I was wondering has anyone tried the ball diff in the front as I have the spec r diff in the rear?
Would there be any benefit by using the ball diff in the front?
#2004
can anybody explain to me how to get zero rebound.yes i did drill the cap but explain your tricks to build shocks with zero rebound thanks
#2005
1. Fill the shock with oil and remove any air
2. Push the piston fully into the shock
3. "Bend" the bladder slightly and insert it into the shock allowing the oil to spill, then "press" the centre of the bladder with the tip of your pinky finger - a little more oil should spill and the bladder will be held in place by the air pressure
4. Place the cap on the shock, hold the shock by both ends (i.e. shock cap and shock bottom) so that the cap is pressing down on the bladder, then tighten - there's an art to doing this, it feels like you need 6 fingers at first.
#2006
got a t3 '11 on the way
RE gear diff;
Can I use these 50mm drive shafts with this gear diff
I want another complete 50mm cvd's just for the gear diffs, without spending an extortion amount for xray's version. Do I need to use blades for this combo?
RE gear diff;
#2007
im pretty sore u do need to run blades on the cvd
#2008
RE gear diff;
RE gear diff;
mine broke already-i used them up front
btw, that gear diff is ugly... its an NT1 converted diff.
#2009
RE gear diff;
RE gear diff;
Guess you've never had your hands on one, they are much better than the Spec R or 3R diffs. The market conversion job is a bit ugly though, they have a tonne of play too and don't include the shims you need.
#2010
he he, good one... actually, got them both... so i know they're way much better the Spec R or 3R.
built my first gear diff for my cyclone TC and T3'11 from NT1 case and built it like market conversion job, only difference is i used 4 screws. though it runs really well, i still find it ugly.
i re-built my T3 gear diff
and finally have been very satisfied by it... performs really well... looks way more nicer than my previous gear diff
