Xray T3 2011
#1951
Talking bout rebound does more rebound give more grip or is it less .
Ive heard different views on rebound . Some say more rebound is more
Grip .....
Grip .....
#1952
hi everybody,
one question:
may i use my yokomo gear diff on the t3 without making any changes??
tnx
one question:
tnx
#1953
Weekend. I found the car was easyer to drive wen i went from
35wt to 40wt oil ..still got some things to try at the next meeting
#1955
I just got my xray t3 11 . I set it up just like the setup sheet said do. I found that I could not go into the turn or come out of the turn with out loosing my rear end. I need help.
#1956
Some quick things you can do:
Increase rear camber.
Decrease front camber.
Add more rake in ride height ( lower front end, higher rear end but do not go overboard)
thicker shock oil will sometimes make the car more forgiving.
Hope this helps!
#1957
Also check your front caster blocks are on the right sides. i had this problem and realised i had forgot the check when installing.
#1958
thank you for your help .
#1959
Looking to buy a clean Xray T3 2011 roller that was run only on carpet! Pm me with details. Pics to [email protected]
#1960
My lucky day....
#1961
#1963
has anyone used these on the t3 ? do they realy make any difference on the track
http://www.teamxray.com/teamxray/pro...p?prod_id=2827
and these will they be better then the kit outdrives?
http://www.teamxray.com/teamxray/pro...p?prod_id=2764
#1964
I have used the collars on my 10 and 11. I can't imagine ever being able to feel the difference even on the highest bite personally. The XRay sway bar mount molds are pretty accurate and the set screw adjustment goes a long way towards eliminating the slop when set properly.
#1965
Elliot Harper told me that they can also reduce the amount of steering, so I haven't used them since.
They will obviously last better than the kit items, but you will wear out the blades you require to run those.
Skiddins
