Like Tree2Likes
Xray T3 2011
Old 04-08-2011, 04:01 AM
  #1921
Con
08 &09 diffs will fit.Anything older ...the gear offset is wrong.
Con is offline
Old 04-08-2011, 04:27 AM
  #1922
gonzo416's Avatar
Trader Rating: 39 (98%+)
What shims are being used to stop the spec r gear diff from moving side to side in the Xray T2 08 / 09 / T3? Part # please. I know the opening has to be 10mm.
gonzo416 is offline
Old 04-08-2011, 05:56 AM
  #1923
Just try a very slim "O" ring on one side, does a great job for me
shrek54 is offline
Old 04-08-2011, 06:15 AM
  #1924
gonzo416's Avatar
Do you mean a rubber O-ring?
gonzo416 is offline
Old 04-08-2011, 06:51 AM
  #1925
gonzo416's Avatar
Originally Posted by RC MARKET View Post
you can use XRAY many type ball joint fit to use !
XRAY # 302653 & 302654
Anyone know which would be the rite size to replace the 90 2314 HEX SCREW SH M3x14 and the 30 2664 T2 BALL JOINT 5 MM UNIDIRECTIONAL? I'm trying to find the rite sized parts for this mod because the 3X14 screw that goes into the top of the upright hits the rim. I don't want to order the wrong parts.
gonzo416 is offline
Old 04-08-2011, 06:58 AM
  #1926
M-Technic's Avatar
Trader Rating: 15 (100%+)
The pulley will need to be changed to 38t which can be bought separate from the diff.
M-Technic is offline
Old 04-08-2011, 09:07 AM
  #1927
Dane's Avatar
Trader Rating: 26 (100%+)
+1
Dane is offline
Old 04-08-2011, 01:12 PM
  #1928
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
I forget what the part numbers were, but I used the hot bodies shim sets for the cyclone tc. 10mm id and 0.1/0.2mm thickness.
rx7ttlm is offline
Old 04-08-2011, 04:45 PM
  #1929
bigdadracing's Avatar
crc makes shims for that too
bigdadracing is offline
Old 04-08-2011, 04:49 PM
  #1930
gonzo416's Avatar
Thanks guys. My buddy just found the 1mm offset diff bearing holders.
gonzo416 is offline
Old 04-09-2011, 04:51 AM
  #1931
Yep, rubber "o" ring will do and is a lot easyer that messing around trying to find metal shims to do the job,
I used a 1mm x 8mm id o ring stretched over the case.
did the job perfect
shrek54 is offline
Old 04-09-2011, 07:50 AM
  #1932
32819toon's Avatar
Will a T2 007 diff fit ? Can the T3 38T pulley be used to replace the one on that diff ? Will that do the job, or does it just not fit the T3 ?
Thanks for your help
32819toon is offline
Old 04-09-2011, 08:04 AM
  #1933
trerc's Avatar
Trader Rating: 89 (100%+)
T2 and T2 007.
Yes but you will need longer belts. It's not the pulley but offset of the actual diff outdrives in relation to the chassis and bulkhead is why the diffs won't work in the T3, it's not possible even with option parts to change that. Hope that makes some sense...
trerc is offline
Old 04-09-2011, 08:28 AM
  #1934
32819toon's Avatar
Originally Posted by trerc View Post
T2 and T2 007.
Yes it does, thanks for your help. I'm brand new to Xray & the different models are difficult to get used to.
Old 04-09-2011, 08:39 AM
  #1935
trerc's Avatar
Xray offers a quick cross reference guide youcan download from their site which is very helpful when seeing what will interchange between models.
trerc is offline
