Like Tree2Likes
Xray T3 2011
Old 03-20-2011, 03:08 PM
  #1801
Fred Hubbard's Avatar
Originally Posted by JayBee View Post
Are the kit shock setup the cats' meow, or should I invest in some aluminum ones?
Most of the US team run the kit shocks. Although lap times are the same using either, the aluminum shocks tend to generate a tiny bit more traction.
EDIT: Just read Korey's post, so ya what he said
Fred Hubbard is offline
Old 03-20-2011, 03:29 PM
  #1802
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks guys Are those the #308306 ones, or different ones?
JayBee is offline
Old 03-20-2011, 04:22 PM
  #1803
(2) X 308306-O is what you want. The piston, shock shaft are different than what is included with the kit shocks.
Old 03-20-2011, 07:51 PM
  #1804
Hi Guys, what are the car chartaristics of flipping the servo like the picture same as the tamiya and also the near upper bulkheads?
Ricky
prodriver is offline
Old 03-20-2011, 09:11 PM
  #1805
As far as I am aware, it changes nothing in terms of car characteristics, just gives you a bit more space for electronics.
Lycan is offline
Old 03-20-2011, 10:44 PM
  #1806
Korey Harbke's Avatar
Beat ya! Haha. Cya in a few days.
Korey Harbke is offline
Old 03-21-2011, 08:34 AM
  #1807
Dusttt's Avatar
Trader Rating: 134 (100%+)
Originally Posted by Dusttt View Post
I wish the new bulkhead clamps came in a kit with the open ball cups and evreything needed to convert to them. Or a least a list of exactly what is needed.
So anyone have a list or know if it will come as a conversion?
Dusttt is offline
Old 03-21-2011, 01:46 PM
  #1808
ByteStream's Avatar
Which caps do you use for ECS shafts?
305241 - Drive Shaft Replacement Plastic Cap 3.5mm
305240 - Drive Shaft Replacement Plastic Cap 3mm
Not sure why there are 2 different kinds
ByteStream is offline
Old 03-21-2011, 02:11 PM
  #1809
CraigM's Avatar
Trader Rating: 34 (100%+)
The measurement refers to the width of the blade. The kit diff uses the wider ones
CraigM is offline
Old 03-21-2011, 02:17 PM
  #1810
BBSpence's Avatar
Trader Rating: 55 (100%+)
If you have a T3 or 008/009, use 305241. 007 and earlier kits used 305240.
BBSpence is offline
Old 03-21-2011, 09:47 PM
  #1811
entitymugenmtx's Avatar
Trader Rating: 85 (100%+)
Guys I need help, I'm looking to get a new kit it's going to be the T3 2011 or the TRF417 give me all the feed back thanks. PROS AND CONS
entitymugenmtx is offline
Old 03-21-2011, 10:27 PM
  #1812
There really isn't a need to give pros and cons the best thing you can do is to go to your local tracks and see which car is popular
Old 03-21-2011, 10:49 PM
  #1813
RevMaxx's Avatar
i'd say - 'get a T3 '11, kick the guys' asses at the track and make your kit the popular one'
kidding aside, u really can't go wrong either way... choose the car with more support at your track.... parts and set-up
RevMaxx is offline
Old 03-22-2011, 01:41 AM
  #1814
CraigM's Avatar
Definitely T3
Both cars are very similar on pace but the T3 is much stronger and wears much better (except the belts). I had tamiyas for years, but now love my xray
CraigM is offline
Old 03-22-2011, 07:58 AM
  #1815
Chris08527's Avatar
Trader Rating: 16 (100%+)
hey guys,
i see the new upper bulkhead mounts are now out on REDrc. Are they availiable yet in the states???
Chris08527 is offline
