Like Tree2Likes
Xray T3 2011
Old 03-17-2011, 09:26 PM
  #1771
Johnny Wishbone's Avatar
Originally Posted by johnny55
Can someone explain to me how to shim out the out-drives? I am using 50mm and the bones seem to not be in deep enough.
You put a 1mm shim (the black plastic ones work best) between the spool and the outdrive. You'll have to trim the shim so it will fit in the spool recess, this brings the cups out enough so the blades are away from the tip of the outdrive cup and a little stronger. Its also something you should consider if your running the 50mm bog bones with a wide front end setting. (2.25mm arm spacing such as Paul L setups).
Johnny Wishbone is offline
Old 03-17-2011, 10:40 PM
  #1772
Dusttt's Avatar
Trader Rating: 144 (100%+)
So blades with the front spool? that must be with non stock out drives correct?
Dusttt is offline
Old 03-17-2011, 11:25 PM
  #1773
ByteStream's Avatar
Sorry for the late reply, was out racing ... Johnny Wishbone took care of the answer.
ByteStream is offline
Old 03-17-2011, 11:34 PM
  #1774
ByteStream's Avatar
Correct.
Non-Stock Outdrives:
1. Xray Aluminum Outdrives (mixed reviews)
2. Flying Fox Outdrives (awesome)
3. Atomic (never tried them)
Not sure but there may be others ..
Old 03-17-2011, 11:37 PM
  #1775
ByteStream's Avatar
Originally Posted by CraigM
I see paul pretty regularly but I'm not sure exactly what is going on with the shop. I know he's been having a lot of issues with international post so I think he's looking to pick up a distributor in the states.
The FF out drives are great, I use them in mod and my blades last for ages
Any word from him if he is shipping out orders that have already been placed? or is everything in a holding pattern?
Old 03-18-2011, 07:34 AM
  #1776
johnny55's Avatar
Yup. I used the Atomic Aluminum out-drives. The thing about using blades is that you have to check if they have not broken after every run. I neglected to check and had my aluminum chewed all up. I thought that aluminum was the way to go, but I've had a change of heart since my experience. I will try the stock with no blades and hope for the best.
johnny55 is offline
Old 03-18-2011, 08:12 AM
  #1777
Integra's Avatar
Ive ran the Stock pieces that are included in the kit All season and haven't had a Sniff of problems what so ever. What's the particular problem and why are you guys upgrading ?
Integra is offline
Old 03-18-2011, 04:10 PM
  #1778
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
I like the stock pieces too. I seem much more likely tobreak blades, chew up outdrives, and bend/break CVD's in wrecks when I run aluminum outdrives. I would much rather break a plastic spool cup than a blade and bone or ecs.
andrewdoherty is offline
Old 03-18-2011, 04:31 PM
  #1779
jammincrtjames's Avatar
+1
jammincrtjames is offline
Old 03-18-2011, 04:58 PM
  #1780
Originally Posted by Phil C
The new camberlink mounts have landed in the UK heres a quick scan of the info sheet included in the pack....
Anyone know when these will hit the US?
Old 03-18-2011, 05:06 PM
  #1781
fullout's Avatar
Hey buddy,
The plastic develops slop over time plus they can shear or crack. They are fairly durable like everything else xray but will need replacing at some point.
fullout is offline
Old 03-18-2011, 06:40 PM
  #1782
Fred Hubbard's Avatar
When I spoke to RCA this morning they were waiting for a shipment to be delivered sometime today so I'm sure they are in there and local shops should have them within the next couple of weeks. But be sure and let your local shop know to place an order for them if they haven't already.
Fred Hubbard is offline
Old 03-18-2011, 07:25 PM
  #1783
draggin87's Avatar
Trader Rating: 33 (100%+)
i want to up grade because of a nice high speed clipping of a pipe. I skinned the inside tire with the wheels turned and pop went the outdrive, it put me out for the whole day in the first qual (im the only one runnin the 2011, or a xray for that matter). I hope the alu ones will withstand a hit like that and keep going.
draggin87 is offline
Old 03-18-2011, 07:26 PM
  #1784
Skiddins's Avatar
It's worth inspecting them occasionaly as you do get a groove start to appear (front to back) as the pin on the driveshaft slowly wears away at the cup.
After a while you run the risk of the driveshafts 'locking' in position under hard acceleration.
Skiddins
Skiddins is offline
Old 03-18-2011, 08:20 PM
  #1785
Skiddins
Definitely a possibility. I think most chalk it up to personal preference.
In Poland I see AH running the servo possibly servo taped 90* to the current design. Also running the new shock tower mounts front and rear, No front gear diff though.
