Xray T3 2011
#1756
So I finally have my t311 out on the track, setup, and running. I have to say it's the best I have ever built and driven! I am having one particular issue with it though. I keep breaking and losing front blades. Last night I neglected to check for front blades and chewed my aluminum outdrives all up. What should I do to eliminate my blade problems?
#1757
as a new onroad guy i have a few q's
most of the club guys i race with keep telling me to get xray
I know they handle better but that much?
do they break less then other cars?
I notice their is a buget car version t3r is that just a plastic ver of t3?
is the t3r a high end tamiya ta-05v2? how would the two compare?
tanks for the info
tanks for the info
#1758
I would put some black grease on the blades...
#1759
I can't speak to the Xray Aluminum outdrives but I've heard mixed reviews.
I use to run the 52mm shafts with the plastic outdrives without an issue. When I switched to the 50mm shafts I have to shim out the plastic outdrive a bit (1mm) or they will undoubtedly break in a run or two.
I currently run the 52mm Flying Fox outdrives and have the 50mm on order. They are awesome, hardly any wear on the blades. Highly recommneded if you can get in contact with the company. Lately I have heard no response from them ....
Has anyone been in contact with them lately? They make such a good product it would be ashame for others to miss out.
#1761
I've never had an issue with the blades. Make sure they are on tight and do not bind I guess. What length driveshaft are you using?
#1762
The FF out drives are great, I use them in mod and my blades last for ages
#1764
Anyone using the lipo multidiff? The LW drives are sweet.
#1765
#1770
There is another xray outdrive made by atomic which is a steel version. I think this might have been better but the problem is, it's always almost out of stock if you buy it on line.
