Like Tree2Likes
Xray T3 2011
Old 03-11-2011, 12:28 PM
  #1711
Originally Posted by olhipster1
I find the 2011 became loose with the Solaris tires.
i'll try Paul's setup and see what happens.
Thanks for the info everyone.
gotta say the car is probably the best quality of all my cars.
If ur coming sat. Bring it to my pit. We"ll get it right
that's all I've been running is the solaris tire
Al Sodano is offline
Old 03-13-2011, 11:08 AM
  #1712
will the 50mm ecs drive shafts fit this car without problems?
thanks
mwoods is offline
Old 03-13-2011, 05:23 PM
  #1713
Default Roll center holder
What is the advantage of the optional quick roll center holders?
http://www.amainhobbies.com/product_...lder-Orange-22
triple7s is offline
Old 03-13-2011, 05:25 PM
  #1714
Korey Harbke's Avatar
Generally makes the camber links a little shorter. For the most part, the L and H holders work better in most conditions though. They make for a longer camber link which makes the car a lot smoother and easier to drive.
-Korey
Korey Harbke is offline
Old 03-13-2011, 05:52 PM
  #1715
Chris08527's Avatar
Trader Rating: 16 (100%+)
anyone have a part # for the x ray alum outdrives and the replacement blades???
after almost 30 days and no reply from flying fox directly i am throwing in the towel . . .
thanks
Chris
Chris08527 is offline
Old 03-14-2011, 08:02 AM
  #1716
Kwikvdub's Avatar
Trader Rating: 100 (100%+)
Thumbs up
I hear ya Chris!!....... I did the same and got these too: http://www.amainhobbies.com/product_...aft-Adapters-2
Order them today, you'll be ready by raceday!....... Hope to see you then!
Kwikvdub is offline
Old 03-14-2011, 10:58 AM
  #1717
Luke Hobson's Avatar
Hey guys
Was the first time for me running the new bulkheads this weekend, one thing to note is to make sure you use Xray ball studs otherwise your links will be massively out with HB or tamiya etc.. (around 1.7-2.0mm higher)
I ran the slightly longer link (middle hole) and it was very nice, created much more roll and stability which for the track we tested worked very well.
Also keep an eye out because some ball studs have a flat section at the very top (non Xray I believe) so if they are screwed in fully they can strip out he first threads of the bulkheads and make the stud very tight all the way through.
All in all, great adjustablitly and usual Xray quality.. :-)
Luke Hobson is offline
Old 03-14-2011, 02:36 PM
  #1718
cwoods34's Avatar
Anybody have a spare set (4) of upper bulkhead/shock tower mount pieces?
(reference pic) http://www.nexusracing.com/product_i...oducts_id=1503)
I basically have enough spare parts to build an 008/009 roller but need some oddball parts, so I figured a complete TC would be more useful than a box of randomness. Will probably make it a mod car just for kicks when I'm done. Don't care if they are silver or orange, it's a mutt car anyway!
cwoods34 is offline
Old 03-14-2011, 03:50 PM
  #1719
Skiddins's Avatar
Originally Posted by Luke Hobson
Hey guys
Luke, which track was that?
Tried Paul Lemeiux's -.75 roll centre holders trick, the car was quick but very difficult to drive, went back to 0.00's with +0.75 at the front and the car was just as fast but easier to drive.
Skiddins is offline
Old 03-14-2011, 04:29 PM
  #1720
ardent mate
Old 03-15-2011, 03:39 AM
  #1721
t3 vs t3 2011
how much quicker is the t3 2011 over the t3 ?
thinking bout up grading my t3 to the t3 2011 is it a big difference over last years car
cheers mark
mwoods is offline
Old 03-15-2011, 07:54 AM
  #1722
Skiddins's Avatar
Originally Posted by mwoods
t3 vs t3 2011
cheers mark
Does appear to have more steering, provided you can tune the setup to maintain the balance it's possible a few tenths faster per lap.
It will never be a huge difference though.
Wait until your chassis needs replacing, then get the T3'11 upgrade kit.
Skiddins is offline
Old 03-15-2011, 09:33 AM
  #1723
ive just got my car set up realy well so i mite wait untill after the first round of the stcc to see where everybody is
thanks mark
mwoods is offline
Old 03-15-2011, 10:10 AM
  #1724
JayBee's Avatar
Trader Rating: 31 (100%+)
Hey guys, I need a comprehensive list w/part #'s of the necessary items for this car. Plus throw in some 'upgrades' if you want to. Can anyone oblige me?
JayBee is offline
Old 03-15-2011, 10:44 AM
  #1725
Had my first race meet with a t3 2011 this week. I played with the settings a bit during the course of the day but progress was limited due to setting up the esc at the same time and having to switch tyres halfway through the day due to temps. Well I got the esc fairly much set up but I'm having major problems with traction. Basically I'm under steering on entry and oversteering on exit. I'm fairly agressive in my driving style. Running 2 degrees front and rear camber, rest is stock. The track is 20x45m and Would be considered to have average traction for an asphalt track.
Any tips on set up or a starting point? I've never really understood improving a car's setup and the setup guide that came with the car has way too many options which I don't understand fully.
J-PaP is offline
