Like Tree2Likes
Xray T3 2011
Old 03-04-2011, 09:13 AM
  #1606
hacker's Avatar
Trader Rating: 141 (100%+)
Originally Posted by CraigM View Post
Does anyone make optional belts for the t3, maybe that last a bit longer? I just replaced the front belt and it had really left a lot of belt material in the pulley teeth.
using a gear diff?
hacker is offline
Old 03-04-2011, 06:17 PM
  #1607
Is the T3 2011 using the 2.5mm chassis?
What is the motor dent area thickness?
ioxqq is offline
Old 03-06-2011, 10:17 PM
  #1608
Dusttt's Avatar
Trader Rating: 136 (100%+)
Question. If I run the aluminum shocks on my 2011 do I need to use the short shock shafts?
Dusttt is offline
Old 03-07-2011, 06:56 AM
  #1609
Skiddins's Avatar
2.5mm Chassis
Thickness at motor area is 1mm
Skiddins is offline
Old 03-07-2011, 07:16 AM
  #1610
The Evicerator
The aluminum shock kit comes with the correct shock shafts... they are different alltogether than the shock shafts that are used in the plastic shocks.
Steve Weiss is offline
Old 03-07-2011, 07:58 AM
  #1611
Chubba's Avatar
Hi there. I have just bought a new T3 2011. I am new to the 1:10 ep as I run 1:8 gp. I was wondering what servo do you guys use? Standard size? as I have spares from 1:8.
Any other suggestions and tips for the build and setup?
Chubba is offline
Old 03-07-2011, 09:39 AM
  #1612
John_S's Avatar
The current range of ko propor servos are rather good (rsx range) along with the sanwa 801. I think low profile or standard doesnt matter you just have to make sure the car is good when you balance it. There arent really any issues with the build of the kit. The only tip to follow really is to dremel a flat on the driveshaft pins where the grub screw sits to help stop them coming loose.
John_S is offline
Old 03-07-2011, 11:22 AM
  #1613
StevenOlsen's Avatar
hi guys. looked at the pictures from Euros and both Teemu and juraj has the servo mounted like the Tamiya and yokomo
http://www.teamxray.com/teamxray/sho...02f892376c8735
http://www.teamxray.com/teamxray/sho...cc542f7648ffc0
perhaps thats how the servo position is going to be on the T3 '12
steven
StevenOlsen is offline
Old 03-07-2011, 11:42 AM
  #1614
Dusttt's Avatar
Thanks Steve!! Thanks for all the help at the track too.
I was thinking that maybe I had the wrong shafts in because my car had soooo much steering that I had dual rate to zero and epa to 60% and still too much steering. It wasnt loose though. I am going to tear it down tonight and check everything out. I had white 17.5 springs on front and the kit 14s on the back. My oils were assoociated 55 in front and 45 rear. Probably time to get some xray oil and new orings.
Dusttt is offline
Old 03-07-2011, 12:10 PM
  #1615
Dusttt's Avatar
Hey also does anyone know the covnversion calculation for CST vs WT in the oils.
Dusttt is offline
Old 03-07-2011, 01:00 PM
  #1616
Trader Rating: 19 (100%+)
I don't think there is a "conversion calculation". I believe that each brand needs to be measured for accurate readings. Here is a handy listing that was put up on the Internet:
http://www.twf8.ws/php/index.php?opt...per&Itemid=175
Advil is offline
Old 03-07-2011, 06:43 PM
  #1617
Chubba's Avatar
Thanks for the information. Also what is a good starting point for the motor pinion. I am thinking of using a 13.5T motor or should I be using another T motor?
Chubba is offline
Old 03-07-2011, 08:49 PM
  #1618
Trader Rating: 5 (86%+)
Default stock racing
have a little mercy on me guys...new to this TC stuff...is the internal ratio of the t3 1.9? Also, does anyone have a setup for high bite carpet running tekin, duo3 17.5 blinky light (stock)...is box setup a good starting point or would someone like to throw me a bone (setup)!!!!!???!!??oh yeah..track is about 70ftx30ft..
obi wun is offline
Old 03-07-2011, 09:16 PM
  #1619
Fred Hubbard's Avatar
Yes it's 1.9. I recommend starting with EA's setup from the 'Birds and talk to him about his setup from the last Mid West Grand Slam they both are really good.
EA's 2011 Snowbird Nationals 17.5 Setup
Fred Hubbard is offline
Old 03-07-2011, 09:20 PM
  #1620
thanks for the setup information...last question for the night..what is the difference between the exotec chassis and the stock chassis...i think i spelled that right...
obi wun is offline
