Old 02-28-2011, 12:47 PM   #1576
John_S's Avatar
Thanks. I was asking because i was running your setup from the "Birds" in Blinky and it works well. However I go through a range of how the car responds through a heat. First, the cars starts out with a little push(first minute) then runs real good for 2-3 mins, then the car gets loose and un predictable later in the heat. This occurs regularly. I am using the same DR setup as you stated but someone told me to run about 70% DR and let the car come to you. I didn't like that because, I believe I will be sacrificing a lot of speed for the first two mins.
BTW I run at Horsham where Larry Fairtrace, Shreffler, Hanulec, Haynes(sometimes runs). So the competition is pretty steep and I need everything I can get to keep up with those guys.
Any ideas would be greatly appreciated.
What do you do for tyre prep?
John_S is offline   Reply With Quote
Old 02-28-2011, 12:52 PM   #1577
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Im using Solaris tires with full sxt on the rear and half on the front. I prep them like 20 mins before the heat and clean them with Ronsonal before putting the sxt on.
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 02-28-2011, 01:01 PM   #1578
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
I was going to ask about tire prep too but see you answered it already. Are the SolaIis tires the ones you have to run? Is everyone using SXT there as well? Ive found to ONLY clean your tires with what sauce you use. It makes a huge difference in the amount of traction you have. I clean as soon as I get done running with sauce and let sit till my next run. They I'll sauce (Full and full for me) and let sit 20-30min and leave wet until I put them right on the track. It could be that your car is pushing the first 2 min due to not saucing the whole front tire and could be using the sauce up and causing it to get erratic. Maybe try full sauce on the front next time.
Ive also found SXT doesnt work well anywhere where paragon or odorless paragon are being used for some reason. At our local track we use paragon and if you use SXT it does exactly what you are describing and builds up gunk on the tire.
Originally Posted by gofasteddy View Post
yea i know it wasnt meant for me. i guess i should have ask, how would that help me? as in driving better didn't mean to be sound abrasive. Thanks for your input.
Making sure your circles are the same both directions will help a ton with driving the car. If you take some dual rate out of it it will be easier to drive till you get used to it and gradually put some back in a little at a time as you get used to it.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-28-2011, 01:08 PM   #1579
fpart's Avatar
Eric,
Thanks, we can only run sxt at the track and solaris tires or Jaco Blues. I have tried full front sauce and it pretty much reacts the same. It is getting quite frustrating as of now.
I will try t without cleaning with ronsonol and see.
スクービーは私のヒーローです!
Old 02-28-2011, 01:12 PM   #1580
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Thumbs up
Race my t3 011 for the first time this weekend and I have to give Xray heads up on the new chassis and the steering setup the car was good with very little setup, had lots of steering had to go down 20 clicks on my D rate to take some of the steering out but all in all I think Xray is going in the right direction.
Me too!....... Same results!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 02-28-2011, 01:12 PM   #1581
fpart's Avatar
Also wanted to ask ...on your Birds setup sheet you don't show the droop. I am running 2mm over ride height front and rear. Is there any way that could be a cause...too much rear droop.
スクービーは私のヒーローです!
Old 02-28-2011, 01:29 PM   #1582
Team EAM
I dont measure the droop...Just up travel. I start mine like this. I set all my camber and ride height and then I put the car on the stand and just tighten the droop screws until the collar just barely touches the spring...in other words no tension on the spring in the rear. In the front I go just a tick further. When you set it on the table I then feel the up travel to see if its equal and adjust so that it is if its slightly off. This should give about 2.5mm of up travel front and rear. At the birds I ended up running a little less up travel somewhere around 2.0 front and rear. The less up travel in the front the more on power steering you'll have and it will react quicker in fast corners.
Also try Jaco Blues with that setup. I ran them at a race last week against Sweeps and Solaris medium tires and was still a lot faster with Jacos.
EA
Contact Us
Old 02-28-2011, 03:07 PM   #1583
hey guys just got a t3 2011 and the diffis pre built do i pull it apart and rebuild it as the t2 i go years ago was the same but no diff lube this one has lube on it any help needed
rufazz is offline   Reply With Quote
Old 02-28-2011, 03:23 PM   #1584
Team EAM
Yes I would take it apart and build it. I dont use the super thin grease that comes in them. I either use AE lube or the new Hudy grease but its hard to find. Black grease on the thrust. Also ensure the thrust washers on are correctly. One is smaller and it goes on the outside.
EA
Contact Us
Old 02-28-2011, 03:41 PM   #1585
CraigX's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to CraigX
When will we see the new T3 2011 options from the Toy Fair?
RC America, Xray, Hudy, Sanwa, Motiv RC, Gravity RC, Max Power America, Protoform, Avid, EA Motorsports, TQ Wire, Prolevel RC, Ulti, 5 Nines
CraigX is offline   Reply With Quote
Old 02-28-2011, 03:47 PM   #1586
Team EAM
Hey Craig,
I think they should be in the order coming in next week Ralph said. I think pretty much everything is in there too (weights, bulkhead clamps, shock bottoms, etc).
When you going to pony up and get a mic for PS3? Cut back on the racing a week and get a mic! LOL
EA
Contact Us
Old 02-28-2011, 03:52 PM   #1587
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
I was curious if the gear diff was ever going to be released lol.
Does ANYONE have a SPEC R diff in stock?!
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 02-28-2011, 04:07 PM   #1588
dougmartin's Avatar
Trader Rating: 14 (100%+)
RCMARKET did last week. My buddy and I got 3 of them. Shipped from Hong Kong to Canada in a week.
dougmartin is offline   Reply With Quote
Old 02-28-2011, 04:13 PM   #1589
dougmartin's Avatar
For those guys that have tested the gear diff did you find you changed your setup some to get the right feel. I just got mine and only had 3k oil to put in car rotated threw corners nice but was very twitchy....would going to the 1-2k oil smooth it out or make it worse.
Thanks....oh and I have the T3'10
Old 02-28-2011, 04:31 PM   #1590
rx7ttlm's Avatar
if it was twitchy midcorner to exit on power going to 1-2k would make it less twitchy.
