Xray T3 2011
#1561
There's also been some guys at the track that have broken spool outdrives. I haven't had that problem, but I do keep spares of those as well, same with CVD blades for the rear.
That's the minimum I'd go with, but I also keep spare spur gears, belts, bearings, and suspension pins, mainly because I really don't like to have my day ended due to breakage.
#1562
So far for me I've broken one front arm, 2 steering knuckles, 2 C-hubs and a rear hub. I keep enough spares to put new arms and hubs at each corner, as well as an extra set of c-hubs and steering knuckles. [all from very hard hits due to driving error, contact with other cars hasn't resulted in any breakages]
BTW you guys run ceramics?
#1563
I like to run ceramic balls in all my ball diffs, but I use standard ball bearings everywhere else, I'm not fast enough to justify the extra cost over a $9 10 pack of bearings for the common sizes on the car.
#1564
Skiddins
#1565
Cant remember when xray usually brings out their next new ride is it near the end of the year or begining of the next?
#1566
Trader Rating: 102 (100%+)
i think end of year.
Oct Nov.
or maybe i took too many pain killers this morning..and have my calendars mixed.
Oct Nov.
#1568
Race my t3 011 for the first time this weekend and I have to give Xray heads up on the new chassis and the steering setup the car was good with very little setup, had lots of steering had to go down 20 clicks on my D rate to take some of the steering out but all in all I think Xray is going in the right direction.
#1569
I was wondering what most XRAY driver use for their steering throw(EPA) when running on carpet. If there is an calculation based on track width please let me know that also.
#1570
EA
#1571
I always set my radio to full throw without binding the servo up. Meaning the Steering block bottoms out right at the caster block and doesnt pull it further. I never remove dual rate from there and this is what I call "full dual rate". I know Paul L and Drew E also run their cars like this too.
EA
EA
#1572
You will have to adjust your epa first before steering throw to get equal circles in both directions. On my Futaba my dual rate is at 100 and I just adjust EPA to get equal steering. If everything is set perfectly square then circles should be the same both directions but usually the servo is just a tick off and linkages are a tick off. I think my EPA is set at 70 and 76 so it makes my circles the same. That make sense?
EA
#1573
Thanks. I was asking because i was running your setup from the "Birds" in Blinky and it works well. However I go through a range of how the car responds through a heat. First, the cars starts out with a little push(first minute) then runs real good for 2-3 mins, then the car gets loose and un predictable later in the heat. This occurs regularly. I am using the same DR setup as you stated but someone told me to run about 70% DR and let the car come to you. I didn't like that because, I believe I will be sacrificing a lot of speed for the first two mins.
BTW I run at Horsham where Larry Fairtrace, Shreffler, Hanulec, Haynes(sometimes runs). So the competition is pretty steep and I need everything I can get to keep up with those guys.
Any ideas would be greatly appreciated.
#1574
i built my T3R yesterday and I got one thing to say. It was the best overall package I have built so far. I have also built a capricorn and a tamiya and they are not ever close to the quality of the xray. I cant wait for my NT1 WC to arrive now.
#1575
It wasnt meant for you. It was in response to Fparts question. I didnt see where you asked a question in your post?
EA
EA
