EPIC "D3" Duo 3
#122
Man up, Motor up.... Crank it up!?
#123
Epic heroes are like Aragron from the LOTR series or Odysseus from the Odyssey.
These are people with a lot of talent and ability, but no special powers (fly, laser beam eyes, super-strength).
#125
I tried the Duo 3 17.5 non boost last night on my touring car. It's a lot faster than the Nemesis 17.5 with the same gear ratio. I don't think it runs cooler than the Nemesis though but it has a lot more power and torque. I am happy with the motor
#126
Hey Windsor Thanks for the support! Normally I start with no timing on the motor with open class and once I feel like I have found the correct gear (usually close for all good size tracks) and I want just a little more I'll start adding timing to the motor. I will try to post a picture of a dyno sheet tonight at 0 and full timing so you guys can see the difference. Its not as much as you think but does make a difference.
At Vegas with the duo 2 I was about 2 notches past 0 in the open class with a 6.3FDR. I think my setup is on the Tekin site for the speedo settings.
EA
EA
Eric
Would be interested in more info on V212 setups with this motor. The Tekin site does not have any V212 setups for OnRoad. The above questions were originally in reference to the 1/12th 17.5 Open & then Spec. Are you really running a 6.3 (161mm) for Open and 4.15 (105mm) Spec for your rollouts? Seems huge. I'm running Duo 1 and Duo 2 in those classes and it seems I would be way off if that is the area you're running in. I'm running the D3 in my Open 13.5 WGT. Strong runner - very pleased with bottom and top-end on this motor! Makes the Nemesis look like a boat anchor!
#129
Eric
#130
Non-boosted 17.5
I'm going to start racing in a non-boosted class, should I find my gearing first or set motor timing?
#131
http://www.rctech.net/forum/8309743-post106.html
#132
EA posted something earlier about non-boosted classes.
#133
Eric
#134
Team EAM
Eric
EA
#135
Eric
