EPIC "D3" Duo 3
#107
Thanks Eric.
Are you going to any of the grand slam races (MSI this weekend)?
I didn't see you at the champs either.
What FDR would you run if you were running a Duo 2?
Thanks!
Rob
Thanks!
Rob
#108
Hey Wiita,
Ive only ran the motor in 17.5 TC thus far. But I have ran it at zero and full timing and the difference is very little on gearing. Probably 2 teeth max. On the dyno you gain about 1000rpm at full timing and increased wattage across the board. So far its ran best for me at full timing in TC as well. The motor runs cooler to me also than a D2 or D1.
EA
EA
#110
I am noticing that the more changes I made to my D3 setup (gearing, timing, speedo) the less happy I am with the car. I think I really nailed it on the first setup, and wrenched my way out of it! I need to start back at my baseline.
#111
Team EAM
EA
#112
The timing on my last post wasn't very good. I should point out I now buy all my motors from EA and they're always very fast. The nice thing about buying from a tuner is that they weed out the duds. If you find one you trust, that's the way to go.
I'm looking forward to trying a D3. I've tried every motor made, I think, and DUO is always the fastest.
#113
did anyone used 4.5/5.0 turn for TC modified ???
any comments ???
i really want one to replace my old 5.0r.
any comments ???
#116
Alright guys, Here's the magical question. Up here we usually run open speedo with our 17.5 1/12 scales. Since there are a bunch of guys on this forum that know what they are talking about. Would I run any timing in the motor when I run in the 17.5 class at the birds? any help greatly appreciated! I have had great luck with your products EA. Thanks for the quality motors.
#117
Team EAM
At Vegas with the duo 2 I was about 2 notches past 0 in the open class with a 6.3FDR. I think my setup is on the Tekin site for the speedo settings.
EA
#118
Hey Windsor Thanks for the support! Normally I start with no timing on the motor with open class and once I feel like I have found the correct gear (usually close for all good size tracks) and I want just a little more I'll start adding timing to the motor. I will try to post a picture of a dyno sheet tonight at 0 and full timing so you guys can see the difference. Its not as much as you think but does make a difference.
EA
EA
