Old 11-24-2010, 12:45 PM   #91
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by R3VoLuTiOn View Post
how do i differentiate between old and new batch of duo3's?
There has only been 2 batches of Duo 3's thus far. There is not a difference in motors. Some do have very weak rotors though and only way to get one thats not is buy from someone that goes through them and weeds those out. But as far as on track performance between 1st and 2nd batch I havent seen any or any differences on the dyno other than ones with weak rotors. Those you can tell a difference....HOT OR COLD. FWIW Rotors get worse when hot.
Their is an updated one coming in the next batch that is supposed to have notches on the endbell to see how much timing you are putting in them (Like the duo 2).
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 11-26-2010, 06:26 AM   #92
idbdoug's Avatar
Trader Rating: 33 (100%+)
Originally Posted by JFuel11 View Post
There are some around that people have been testing, but I am not aware of any that have been shipped with motors and I am not aware of any availabe for sale at this point. Now a large motor supplier that purchases 100s of motors at a time may have the ability to take the stock rotors and check them and determine that some are weaker than others and use those for 1s application. That is very possible. It is even possible that they have some 1s rotors to play and test. However, they are not being sold via epic to the masses yet. Once they are comfortable with the performance of them, they will be released.
I hope this helps.
I am only a team guy as well and do not have full knowledge of all the workings inside and out of Epic. I am only offering what I know at this point to try and help.
Best luck to all!
Yep, 1S rotors are for sale:
http://www.amainhobbies.com/product_...h-RPM-D3-Rotor
idbdoug
idbdoug is offline   Reply With Quote
Old 11-26-2010, 10:20 AM   #93
Racecrafter's Avatar
Trader Rating: 25 (96%+)
idbdoug
Smart marketing and a good way to utilize the rotor tester.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 11-26-2010, 10:27 AM   #94
WIITA's Avatar
Trader Rating: 42 (100%+)
Anybody running any endbell timing in this motor like the duo 2? how about you EA?
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 11-26-2010, 10:42 AM   #95
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
I have very limited time on a 1S 17.5 boosted scenario on a tight 12th scale track. Once I can timed to roughly .1" (instead of the factory suggested .08"), it came to life. Practice time ran out and I fell back on the Duo1. It's early, but I think there is hope this time!
Brian
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 11-26-2010, 02:52 PM   #96
WIITA's Avatar
Brian
Brian, Is it possible to elaborate on this a little. What do you mean .1"? Sorry I'm fairly new to all this. Thanks kindly.
Old 11-26-2010, 03:12 PM   #97
Team EAM
Hey Wiita,
Ive only ran the motor in 17.5 TC thus far. But I have ran it at zero and full timing and the difference is very little on gearing. Probably 2 teeth max. On the dyno you gain about 1000rpm at full timing and increased wattage across the board. So far its ran best for me at full timing in TC as well. The motor runs cooler to me also than a D2 or D1.
EA
Contact Us
Old 11-26-2010, 06:51 PM   #98
The 17.5 D3 that I purchased is a Trinity and not a rebadged piece. The instructions call out for increased timing to be not much more then .080 of an inch past their 0 hash mark. If Eric says newer ones will come with actual degree marks etched in, that will be a better design. Moving the endbell randomly "this much" seems kinda lacking. I did not twist the timing to max to see if there was a mechanical limit.... there might be. Like I said, I only ran the motor 3 times at different timed locations with the same roll out. I never got an indication that it was going to run hot or be finicky. This could be the best motor since the Duo1, but I don't know if it's going to be better. I wont get to test 17.5 for some time now.
Team Roche USA
Old 11-27-2010, 06:12 AM   #99
WIITA's Avatar
Ah, now I see what you mean. Thanks a lot for the explanation. Much appreciated.
Old 11-27-2010, 07:29 AM   #100
idbdoug's Avatar
Yes the timing is restricted physically/mechanically by the slot width
idbdoug
Old 11-27-2010, 08:51 AM   #101
In a 12th scale would it still be a good idea to max the timing out in the can instead of using the tekin?
gguertin145 is offline   Reply With Quote
Old 11-27-2010, 04:30 PM   #102
RDOUBLEDAY's Avatar
It depends , If your allowed to run boost , I would say if you can run boost , run it and no timing on the motor.
Mugen Mbx6 Eco .
RDOUBLEDAY is offline   Reply With Quote
Old 11-27-2010, 09:39 PM   #103
.080 past 0 is aproximatly 7.5 deg of timing, .100 is about 10deg of timing.. this is by measuring from 0deg mark.. hope that helps to understand what the timing may be..
JP
jon Perkins is offline   Reply With Quote
Old 11-27-2010, 09:53 PM   #104
Hey Wiita,
EA
I had the same experience as Eric with the D3 in stock no timing sedan. Full timing in the motor worked best (endbell turned till it stops).
malkiy is offline   Reply With Quote
Old 12-07-2010, 08:52 AM   #105
anybody have any gearing recomendations for this motor?
I was running a Duo 2 with max timing in spec rubber touring (17.5).
Is there a standard gear up/down that people are using with this motor?
Should I go up one tooth, two teeth, three?
Thanks!
Rob
Pink and Blue is offline   Reply With Quote
