Old 11-08-2010, 02:57 PM   #61
wa7ash's Avatar
Trader Rating: 37 (100%+)
Anyone know where and if I can buy a sensor board for the Epic DUO2 ?
I have tried emailing Epic, but as most people that have tried that already know, I got no response.
This new DUO3 sounds exciting and I am tempted to get one, but the non existing after sale service at Team Epic makes me wonder.
Xray | Muchmore | Sanwa | Orion | G-Force | Scorpion | Fantom
wa7ash is offline   Reply With Quote
Old 11-08-2010, 03:07 PM   #62
Johnny Wishbone's Avatar
Yes you can, they are listed on the web site.
Old 11-08-2010, 03:15 PM   #63
M-Technic's Avatar
Trader Rating: 15 (100%+)
Hi wa7ash,
Sorry you have not received an email response. Have you checked your spam folder? You may want to call Team Epic directly. The phone number is (386) 668-7771. The part number for the Duo2 replacement sensor is TEP1020. Hope this helps!
-T.J.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 11-08-2010, 04:22 PM   #64
nashrcracer's Avatar
R/C Tech Charter Subscriber
after taking my d3 apart and putting on my duo2 endbell I can say that they are the same. even the sensor plate has the same markings and if the sensor is as I suspect it, it has the same position as the 2. now the holes in the can and the new sintered rotor instead of the plastic coated one in the 2 is probably making it a lot cooler running motor. but the problem with that is with stock spec you get too high a FDR and it still bogs. but in open ESC I bet it will be sweet and even in stock spec it seems to be running considerably cooler then my duo2. this would allow it not to fade as much as the duo2. one thing I want to check is the impedance compared to a duo 1 or 2 that would clinch it for the stator being the same also.
I think I'm going to take the rotor out of it and run it in my duo2 and see. and then swap it for my duo 1. turbo dyno here I come.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 11-08-2010, 05:17 PM   #65
Originally Posted by MatsNorway View Post
... And power does vary extremely from producer to producer.
for instance corally spesifies their red series 4.5T to have 1350 Watts!
My Corally X-BP got under 500watts so i don`t need a red series 4.5T if i need to replace it.
Same if you want a different brand the Novak 4.5T got less than half (530watts)
Not even Trinity in their finest hour would make up a claim this far out of the box. A 100% efficient motor would need to draw 182.4 Amps to make 1350W @ 7.4V. And do you seriously believe that you can channel almost 2 horsepower through an 1/8" shaft? I've dyno tested Novak's motors and found their numbers to be pretty accurate, and haven't seen ANY other brands produce significantly different numbers (better or worse). The Duo3 17.5 was almost identical to a Novak, slightly less RPM, slightly more torque.
Kevin Marcy is offline   Reply With Quote
Old 11-08-2010, 09:52 PM   #66
JFuel11's Avatar
Trader Rating: 152 (100%+)
[QUOTE=haywood;8179635]Great motor! Ran it in stock 1/12th scale today had lot of low end and pulled hard down the straight. Came off the track after 8 min. at 135 degrees.[/QUOTE
If you like the motor in a 1s 1/12th now... Wait until the 1s rotors come out, you will be blown away!
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 11-08-2010, 09:54 PM   #67
JFuel11's Avatar
Originally Posted by idbdoug View Post
Were you running in a "no timing speedo" 17.5 class? If so what was your spur and rollout combo?
I tried a 72 spur and it seemed a little short on the punch. I'm going to try a 76 spur next in our "no timing speedo" 17.5 class.
I did run my fastest laps today with the new Duo 3. Just got to figure out the sweet spot on this motor.
idbdoug
There will be a 1s rotor coming out at some point that will increase the performance in a 1s setup...
Sponsors:
Old 11-08-2010, 10:11 PM   #68
Originally Posted by Kevin Marcy View Post
..... A 100% efficient motor would need to draw 182.4 Amps to make 1350W @ 7.4V. ....
finally, a real use for 50C lipo's
1101 is offline   Reply With Quote
Old 11-09-2010, 05:30 AM   #69
Buckaroo's Avatar
FINALLY, a motor manufacturer that will at least go down that road and see if there's going to be any difference! Put me down as "cautiously optimistic".
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-09-2010, 06:45 AM   #70
wa7ash's Avatar
Thank you all for the feedback, I have found and ordered the sensor board.
Old 11-10-2010, 07:52 AM   #71
M-Technic's Avatar
Trinity's shipment of 17.5 D3's was delayed, but should still be here by the end of this week.
Old 11-19-2010, 12:15 PM   #72
Trader Rating: 75 (100%+)
I noticed Stromerhobbies has them back in stock.
Markus is offline   Reply With Quote
Old 11-19-2010, 12:50 PM   #73
BCbud's Avatar
[QUOTE=JFuel11;8185070]
Good day!
Will they be ROAR approved?
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 11-19-2010, 05:52 PM   #74
[QUOTE=BCbud;8232133]
Good day!
http://www.roarracing.org/?page_id=251
Already are, just scroll down.
Gary Lanzer
Old 11-19-2010, 06:11 PM   #75
BCbud's Avatar
[QUOTE=Johnny Wishbone;8233126]
What one is the one with the new 1 cell rotor?
Recycled teenager.
