Old 11-07-2011, 07:40 AM   #571
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by gashuffer View Post
Did email them. Got no response.
I'm sorry but who ever packed this package up did not make a mistake. They just don't care. It was thrown together.
I'd figure someone here would know. There is no harm in asking.
Yea you emailed them Saturday 40 minutes before you posted here. Really giving them a lot of time to get back to you on a weekend.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 11-07-2011, 01:14 PM   #572
gashuffer's Avatar
Trader Rating: 48 (100%+)
EA
You must really be bored. That's still no excuse for lack of attention in the workplace.
Emailed P. All sorted out. Since your so interested with my post. Goodday.
T-Sal
gashuffer is offline   Reply With Quote
Old 11-07-2011, 02:21 PM   #573
Team EAM
Nope not bored...while they dont patrol this board I do (see signature). Glad Tony got it taken care of as he should have. Thats what the customer service email is for.
EA
Contact Us
Old 11-07-2011, 02:54 PM   #574
gashuffer's Avatar
Yep Alls well.
T-Sal
Old 11-11-2011, 10:25 AM   #575
DRRC's Avatar
Trader Rating: 57 (98%+)
Does anyone know the specs of the bearings and where can I get one?
Team Wife
Mugen Seiki Racing
Mugenracing.com
DRRC is offline   Reply With Quote
Old 11-12-2011, 07:21 PM   #576
Default timing help
im running a stock pan car class on carpet. im using the 17.5 d3 with a tekin rs esc. were not allowed to run any timing or anything in the esc. only can adjust motor timing. can anyone give me some advice on how much timing to run on these motors? thanks, matt
dms888 is offline   Reply With Quote
Old 11-12-2011, 08:57 PM   #577
James35's Avatar
Disregard....
Deleted my post.
James Van Horn
McPappy Racing
James35 is offline   Reply With Quote
Old 11-14-2011, 07:06 PM   #578
Dog Bone's Avatar
Hey guys, I recently purchased a Team EPIC D3 "Monster Horsepower" 13.5t to run in a boosted touring car class. I'm using a Tekin RS as a speedo.
I've got a problem where I have excessive 'drag' brake during corner entry. I quote 'drag' since I have no drag brake specified on the speedo. The only thing I can think of is that the motor itself is causing the drag. I've noticed that there's quite a bit of 'cog' in the motor when you rotate the wheels by hand - strong magnets, I assume.
I'd like the motor to run a bit freer; my first thought was to add some push control, but it (strangely enough) didn't have any effect. I know in 1/12 that push control works exrtremely well, allowing the car to roll through the corners better. However, it doesn't seem to have much effect with the D3.
Anyone have any suggestions? The drive train runs free, so I don't think the issue comes from that.
Thanks!
(I'm also going to post this on the Tekin RS thread, as this thread hasn't seen much activity lately).
Ken Miller
T4 2015
CRC Twenty5
Dog Bone is offline   Reply With Quote
Old 11-14-2011, 07:43 PM   #579
ShaunMac's Avatar
Does the motor get hot fast? Check the bearings in the motor and make sure it isn't shimmed too tight. Does it have the stock purple rotor in it? My D3 doesn't feel notchy or tight with the stock purple rotor in it. I know with a larger tuning rotor it will feel that way.
You can also try running a larger pinion and spur. The bigger pinion will let the car roll more freely than a smaller one.
Good luck
ShaunMac is offline   Reply With Quote
Old 11-14-2011, 08:13 PM   #580
cocojam's Avatar
Trader Rating: 47 (100%+)
Check the soldering of your esc power wires on to the buss bars of your motor as some wire strands could have connected to the other terminals during your soldering. Even a tiny single strand could induce a "braking" effect when you are in neutral. Just my two cents worth.
SJF01 - F103RM - F104Pro - 3rF109 - TB EvoV
Wild Willy 1 - Road Wizard - Can-Am Lola
Dynamic 1500 - Wilga 2000 - Zephyr V70 - FMS FW190 - TWM Skylink
TWM Katana - Zeta Horten BV38 - Freewing Pandora
cocojam is offline   Reply With Quote
Old 11-14-2011, 10:18 PM   #581
I agree with this post, Has happend to me many times.
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 11-15-2011, 06:35 AM   #582
Dog Bone's Avatar
Good luck
Nope, not hot at all. Motor comes off the track at about 120F. I don't run turbo, just boost. Yes, I believe it has the stock purple rotor.
Ken Miller
T4 2015
CRC Twenty5
Old 11-15-2011, 06:37 AM   #583
Dog Bone's Avatar
Don't think this is the cause - only a small amount of wire is exposed, and what is exposed is inserted through the holes in the terminals, and soldered on the other side. So, it's pretty much impossible to have strands crossing over.
I'll check it out tho. Thanks for the suggestion.
Ken Miller
T4 2015
CRC Twenty5
Old 11-15-2011, 07:38 AM   #584
Default starting point
Hi guys, finally ordered a D3 13.5t today after much deliberation!!
Anything I need to be aware of? ie what FDR should I run (indoor track 30mtr x 20mtr), how much timing should I put on the motor itself?
I will be running boosted.
Mb3195 is offline   Reply With Quote
Old 11-15-2011, 09:10 AM   #585
Capt'N_Slow's Avatar
Have seen your solder job at the track and your leads look good. I would take apart the motor and roll the front/back bearings to see if they are free.
Next is shine a flash light and examine the stators surface a couple of my d3's after running the extra glue (stator epoxy) would melt into the center and rub against the magnet causing drag. Had to slowly file at it until flat again.
Micah
Capt'N_Slow is offline   Reply With Quote
