Old 08-28-2011, 07:34 AM   #526
hacker's Avatar
Trader Rating: 141 (100%+)
I'm finding this motor to be very soft compared to others. This is with standard 0 timing. Maybe I got a monday or friday motor, but it doesnt seem to rev out like my other motors. Running 13.5 about 7.5fdr with tekin esc
hacker is offline   Reply With Quote
Old 08-28-2011, 07:54 AM   #527
HarryLeach's Avatar
Send a message via AIM to HarryLeach
Is that with a boosted profile, or blinky?
Privateer racing lots of stuff.
Remember kids, racing isn't fair!
HarryLeach is offline   Reply With Quote
Old 08-28-2011, 12:47 PM   #528
Hello,
I like the duo 3 boosted feeling. But i have some rotor clearance problem.
My washers bronze is a little damaged after only 10 packs...
Am i alone with this problem ?
Manson is offline   Reply With Quote
Old 08-28-2011, 01:13 PM   #529
Default WGT DUO 3 13.5 BLINKY
Attending the IIC and competing in WGT 13.5 blinky looking for rollout and motor timing for my DUO 3 Txs in advance for any help offered.
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 08-28-2011, 05:41 PM   #530
ewashburnaf's Avatar
Trader Rating: 14 (100%+)
I would use a Team Epic RevTech for your application over a Duo3
Fishhook
ewashburnaf is offline   Reply With Quote
Old 08-28-2011, 08:31 PM   #531
Still Bill's Avatar
Isn't the RevTech motor applicable to 1 cell oval?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-29-2011, 04:50 AM   #532
hacker's Avatar
boosted.
I find the speed passion motor to have more grunt and top end. I have tried different settings on timing/turbo/motor timing, but it seems to me the D3 is soft in comparison
Old 08-29-2011, 05:41 AM   #533
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
No the ReVtechs were designed around a large Torque power band. They produce more torque across the board with a slight increase in RPM as well.
EA
EAMotorsports is offline   Reply With Quote
Old 08-29-2011, 11:35 AM   #534
corallyman's Avatar
Trader Rating: 99 (100%+)
EA,
Do the ReVtech's and the D3 (17.5) use the exact same tuning rotors?
Are the rotors that come standard in the 17.5 motors of each brand the same rotor type? Which one is it?
Thanks EA,
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 08-29-2011, 11:47 AM   #535
Trader Rating: 72 (100%+)
Default D3 tunning rotor
Hacker: I run a 17.5, and have the 3 rotors. I like the rpm rotor for a more open track, but use the torque when they build a tight track. I have to run blinky mode so it maybe totally different for you, got a good metal fan and some computer CPU heat transfer compound. drp'd my temp 40F on my temp after 6mn. main. was able to add 10 degrees more timing. I have a T2R with gear diffs, ussually 4.1- 3.8 gear ratio. Chris
btrukr is offline   Reply With Quote
Old 08-29-2011, 11:50 AM   #536
Team EAM
Originally Posted by corallyman View Post
EA,
Thanks EA,
Steve
The rotor that comes in the Revtech motor is the same 12.3 broad range rotor as the D3. The others will fit as well. We did get a batch of Revtechs in last week that came with the 12.5 rotor in them. Those are marked though and was just a few that came that way.
EA
Old 08-29-2011, 01:48 PM   #537
Trader Rating: 18 (100%+)
EA
How did those (with the 12.5 rotor) dyno out compared to the 12.3? Much more rpm and watt output on the lower torque settings with just a little more on the high end?
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 09-01-2011, 02:51 AM   #538
Am i the only one who have rotor clearance problem with this motor ?
After only 10 packs the shim is damaged
Old 09-01-2011, 08:50 AM   #539
Looking for some baseline settings. 17.5 TC class, no boost or timing advance at speedo allowed, but you can advance the motor timing. Small, tight track on rubber tires. Looking for a starting point for FDR or rollout settings and motor timing settings for a TC5R, LRP SXX TC Spec, and 17.5 D3 on 2S LiPo. Thanks.
Who the ^&@$#()! Is Jason Branham!?
cjtamu is offline   Reply With Quote
Old 09-01-2011, 09:59 AM   #540
Buckaroo's Avatar
Post
Define "Small, tight track..."
Start with the timing mark on zero (which is not really zero overal timing), and a 4.0 FDR. Adjust timing/gearing from there with an eye to temps and overall performance. Find a high CFM/Amp draw fan(the boss/geisha/fantom fans are all gone, so best option is for a Yeah Racing 25 or 30mm tornado fan) and have it blowing on your motor, wired to battery + and -. Even with ambient temps in the 100s F, it's not uncommon to see setups geared into the 3.2ish FDR running under 160 on some of the larger tracks.
More and more these new motors have enough torque to swing a huge pinion, which helps with overall speed, but don't have enough extra output to pull hard off of the corners, and because of that, blinky is a game of having enough corner speed/motor RPMs to be able to effectively use the motor's power band AFTER apexing the corner. If you're not holding enough corner speed, it's a point-and-shoot affair, and you'll be left in someone elses dust.
Remember, the motor sees only the final number, so wether you're running a primary drive of 94/47 or a 102/51, it's the same thing. Pick gears that physically fit and give you the proper adjustment range up and down for your chassis.
There is also some school of thought that says a smaller/lighter spur/pinion is prefered to a larger spur/pinion combination. Whatever, I find that it's more about adjusting weight balance, but a few mm of movement of the motor fore or aft isn't nearly as effective 10grams of ballast lead properly applied(most chassis need weight added to make tech anyway).
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
