Old 06-24-2011, 12:11 PM   #511
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Don't remove the whole thing! Just loosen the screws a little buddy! Lol no worries we have all been there - keep asking questions bc it's the people who think they automatically know everyone who mess up the worst.
In other words, put it back together but leave those three screws a little loose until you can rotate the center piece.
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 06-24-2011, 12:52 PM   #512
what other company rotors that will fit in the duo3?
thanks
kambing2011 is offline   Reply With Quote
Old 06-24-2011, 03:14 PM   #513
I was removing the whole to take picture about it
When i loose the screw a little it don't move anithing with rotate...
Manson is offline   Reply With Quote
Old 06-24-2011, 07:19 PM   #514
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Mine was difficult to turn as well. I can't figure out if it is the plate that the three screws go through or the plate on the end that the threads go into are causing it. I did get it to a spot I wanted it to be at so I just tightened it back down and will be giving it a try.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-24-2011, 08:00 PM   #515
B4james's Avatar
As you can see in the pic they grind out the areas on the main plate which sometimes creates little burs which stop the plate from moving. If I have one where it doesn't move I tap out the smaller disc and then smooth out any imperfections and re assemble.
Normally after that it works perfectly,
Follow me on Facebook - James Ainslie Designs or on Instagram - JA_Designs
*HEI International for Protoform/Proline/Spaz Stix
*Bitty Design Australia for Bodies and Liquid Mask
* Airbrushmegastore.com for all paint and airbrush supplies
B4james is offline   Reply With Quote
Old 06-25-2011, 01:04 PM   #516
This engine make me crazy
How the center can move because it s one pieces...
Whats the graduation utility if it s can't slip anymore.
I ve try to put the "C plate" directly on the aluminium pieces and put the sensor after. But i can't put it the bearing. That s was just a desesperate try
I will run with this stock timing
Old 06-25-2011, 02:59 PM   #517
Default advice!
hi guys, blew up my new 13.5t orca today! tmps were only peaking at 70 degrees and only second time ive run it so pretty jarred off!
anyway, now need another one, already got a speedpassion which seems very hardy but not as quick as the orca.
ive got a hw xtreme stock running indoor on carpet, track is around 35 mtrs long, racing an xray t3'11.
how would a d3 suit and what sort of settings?
cheers
Mb3195 is offline   Reply With Quote
Old 06-25-2011, 03:18 PM   #518
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-25-2011, 07:55 PM   #519
B4james's Avatar
Please read my post, it is not 1 piece it is two pieces and I would say they have jammed together and this is why they are not moving as they should be.
As I suggested, the disc that has Trinity written on it is a separate piece to the part that has the timing notch marks on it. Turn it upside down and from the inside very lightly tap on different sections of thr small disc and it should come apart. I DO say gently as you don't want to hit it hard and damage or bend it
Old 06-27-2011, 10:12 AM   #520
cheers
The D3 would work fine. You might have to find the right gearing for your track as with anymotor, But the majority of people in the states run some sort of Trinity Duo motor and they usually fill most of the Amains in spec racing.
TEAM ASSOCIATED, SMC BATTERIES, REEDY MOTORS, JACO TIRES, RADIOPOST RADIOS, LRP ELECTRONICS, PROTOFORM BODIES, MAKITA POWER TOOLS, KICKER PEFORMANCE AUDIO, KOLORS BY KROPY, MUCH-, RSD
Mike Blackstock is offline   Reply With Quote
Old 06-27-2011, 10:17 AM   #521
Yes it is two peices. Sometimes it is stuck and needs alittle bit of nudge to move or come loose. He is correct with what he told you to do.
Mike
Old 06-27-2011, 10:51 PM   #522
IIICJACKIII's Avatar
As I suggested, the disc that has Trinity written on it is a separate piece to the part that has the timing notch marks on it. Turn it upside down and from the inside very lightly tap on different sections of thr small disc and it should come apart. I DO say gently as you don't want to hit it hard and damage or bend it[/QUOTE]
I also had the same prob. when I first bought mine. I have fixed it now, all you need to do is sand the outside edge of the smaller pc. a little. Took me about 2 min. to do it. The machining tolerance is a bit tight, or the anodizing.
Hope this helps.
Team Psycho Cells
IIICJACKIII is offline   Reply With Quote
Old 07-21-2011, 11:21 PM   #523
can someone tell me how much timing each notch is on a duo3 thanks!
gguertin145 is offline   Reply With Quote
Old 07-22-2011, 08:06 AM   #524
M-Technic's Avatar
Trader Rating: 15 (100%+)
8 degrees.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 08-28-2011, 02:30 AM   #525
Hi there
What the max endbell timing advance possible on the D3
Also , what the most that the endbell shold be advanced , for 'blinky class' esc's
Cheers
1101 is offline   Reply With Quote
