EPIC "D3" Duo 3
#361
I've got a question about the "ideal" fdr for off-road use (I know I'm in the wrong section but some of the guys are so hooked with these engines so at least I can try it here )
I have a D3 8.5 turns.
I'm driving a X-Factory X6 Squared with a FDR of 8.22 (78 spur and 23 pinion) is this a good thing ? I have some decent speed but it seems I can get more out of the engine. Our track is medium sized (30M straight) and quite smooth (astroturf though: pretty grippy). I've set the motor timing on default and my ESC's timing is default. Is there some target FDR or it's just trail and error?
Thanks in advance
Thanks in advance
#362
need advice, epic D3 10,5t-esc tekin rspro 1/10 scale TC large asphalt track
#363
My front bearing keeps drying up, my TC sounds like a tractor , What grease / oil do you recommend putting in the bearing? standard bearing oil seems to dry up / escape to quickly.
#364
#367
Hi all,
After some assistance with motor timing. How do you go about setting up how much timing to use? Should I be doing this before or after setting up the esc settings? I'm running a sp gt 2.1 with a d3 21.5.
Also what temps should I be looking for max?
#369
need help, i'm running a d3 10,5 and rs pro esc 1/10 TC-boosted class foam tires, large asphalt nitro track, in terms of speed I did'nt have any issue with tekin rspro-lrp x12 10.5(lap times faster than a nitro TC), but with tekin rspro-epic D3 10.5 my laptimes are .40 to .60 sec. slower, i'm not new with setting tekin rs pro, but where is the problem? maybe lrp x12 is faster than epic D3 or there is something wrong? thanks.
#370
#371
Are the motor temperatures the same after a race? Maybe amount of timing in the motor. Seems every motor manufacture has different amount of timing.
#373
#374
Guest
Just picked up a D3 17.5 but haven't ran it yet. I was wondering if these motors are built for Torque or RPM?
