Old 01-10-2011, 07:35 PM   #256
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by waltuo View Post
File size was too big.
Thanks Mike!
The this is the same motor with the top pull at zero timing and the bottom pull at full timing. As you can see there is not a huge difference but it is there. As you apply more voltage or turbo/boost the difference will get larger. This was tested with a spec speedo profile (LRP 007 Comp speedo).
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-10-2011, 08:01 PM   #257
ChadB.'s Avatar
Trader Rating: 21 (100%+)
I've been eying this motor for awhile now and I would like to get some personal opinions on it. What I want is a 17.5 non-boosted and it would go into my sedan. The track I would be racing it on is a pretty large carpet track with about roughly a 100 ft. straightaway. So my question is, is this motor going to have plenty of power for this large track or is it more of a short track motor?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*Daves RC Track*
ChadB. is offline   Reply With Quote
Old 01-10-2011, 08:12 PM   #258
trerc's Avatar
Trader Rating: 89 (100%+)
My track is roughly the same size, I run a non boosted 17.5 Duo 3 with max timing geared at 4.06 and am happy with it, my temps stay between 140-150.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-10-2011, 08:20 PM   #259
Team EAM
I think you will be MORE than happy with a D3 motor in the spec class. This is what I am running mine in at my club track and its faster than anything Ive ran thus far. The new Thunder power motor is close and with some tuning may be as fast but so far the D3 is still king.
EA
Contact Us
Old 01-10-2011, 10:04 PM   #260
ChadB.'s Avatar
EA
Good to know EA, thanks for the help.
Chad Burdick
Old 01-10-2011, 10:16 PM   #261
what is a good gear ration for this motor aon a tight track with an approx 75-80 foot straight?
thank you
gdcopbdcop is offline   Reply With Quote
Old 01-10-2011, 10:17 PM   #262
im sorry, this is for non-ramping 17.5 t/c class
thank you
Old 01-11-2011, 01:09 AM   #263
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
Did I read that dyno right? The rpm's went down as the current went up?
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 01-11-2011, 08:04 AM   #264
theisgroup's Avatar
don't forget that EA runs a load dyno. so torque is a variable as well
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-11-2011, 08:54 AM   #265
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Remember electric motors 101;
Voltage = HP (RPM)
Amperage = Torque
Therefor the more a motor is pulling amperage the less the RPM will be because the electro-magnetic field is larger thus harder to spin the armature (rotor) through it.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 01-11-2011, 09:13 AM   #266
Skitee's Avatar
Hi Guys,
I' like to find out if I need to drop any timing from my boosted esc setup going from a SP v3 13.5 to D3 13.5 and do i run the D3 with timing added on the motor too or leave the motor at 0 ?
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 01-11-2011, 09:20 AM   #267
Team EAM
Yes what Racecrafter posted is the true definition of why. It easier terms though its as Yang said as I use a Load type dyno so as a load is applied to the motor the rpm drops and this is where the amp draw comes in. As you put a heavier load on it the amps go up and rpm goes down.
EA
Contact Us
Old 01-11-2011, 09:38 AM   #268
theisgroup's Avatar
EA
you can tell, EA is turning into a politician. everyone is right, no one is wrong. lol
BTW, package on it way to ya
yang lai
Old 01-11-2011, 09:42 AM   #269
M-Technic's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Skitee View Post
Hi Guys,
What is your ESC setup? I run middle to 1 tick of timing on the motor depending on ambient conditions and the track I am running on.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 01-11-2011, 09:47 AM   #270
Team EAM
LOL...no there ARE people that are wrong...LOL I could never be a politician...I like to tell it how it is to much and not skate around issues!
EA
Contact Us
