Old 01-03-2011, 03:20 PM   #196
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Originally Posted by yumlailai View Post
My motor only works with non sensor mode, is that mean my sensor died? I have taken the sensor out and i cannot see any physical damage. I cleaned it with motor spray and it still doesn't work. Any suggestion on what i should do next?
Thank you
Have you tried a different sensor wire?
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 01-03-2011, 04:01 PM   #197
jammincrtjames's Avatar
Whats is max timing in degrees on the Duo3?
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 01-03-2011, 04:17 PM   #198
yumlailai's Avatar
I did, but it still does not work and I tried my nemesis with the same sensor wire and it work on my nemesis
Thank you
yumlailai is offline   Reply With Quote
Old 01-03-2011, 04:56 PM   #199
MikeXray's Avatar
Trader Rating: 73 (100%+)
Thank you
Usually that is the case, you can get replacement sensors.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-03-2011, 07:27 PM   #200
Trader Rating: 15 (100%+)
Default Gearing
I have a new Xray T3r and I am looking for a ESc and gear settings. I am new to onroad and don't want to smoke the motor. I am using a Duo 3 17.5t with full timing and a Castle Mamba Max Pro.
thanks
Mike
mdhyams is offline   Reply With Quote
Old 01-03-2011, 07:44 PM   #201
Johnny Wishbone's Avatar
Each "mark" is 2 degrees. Each in between is 2 degrees.
So if you go from one hash mark to the next you are advancing ( or retarding) 4 degrees.
In addition to........... (a previous post)
.080 past 0 is aproximatly 7.5 deg of timing, .100 is about 10deg of timing.. this is by measuring from 0deg mark.. hope that helps to understand what the timing may be..
JP
Gary Lanzer
Old 01-03-2011, 07:46 PM   #202
JP
So if you turn it all the way up what are you at for timing?
Old 01-03-2011, 07:48 PM   #203
thanks
Mike
Go back in here and see post #108 and #111 that should get you going.
Gary Lanzer
Old 01-03-2011, 07:51 PM   #204
Off hand I dunno, I don't have any of my stuff right here to measure, but if you measure from 0 to extreme cranked setting then convert you should get a pretty close guesstimate.
Gary Lanzer
Old 01-04-2011, 10:48 AM   #205
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Trinity said starting a 0 deg and each line is 8 deg.
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 01-04-2011, 11:49 AM   #206
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I assume there was an update to the can to include timing hash marks? I must have missed that somewhere along the way, because I only have one line on my motor.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 01-04-2011, 11:50 AM   #207
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Yes they updated them about a month ago (fist of Dec) to include hatch marks. That was the only thing that changed.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-05-2011, 05:24 AM   #208
warnos's Avatar
So does anyone know the the degrees each mark is? There are some saying 2 degrees and some 4.. bit confused..
The marking seem to be the same as the duo 2 motors.. so is each one 4 degrees?
Also when compared to a duo 2 17.5 with open esc..would a good starting point be the same as the duo 2 or add some teeth on the pinion on use a smaller pinion??
Cheers
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 01-05-2011, 07:11 AM   #209
M-Technic's Avatar
Cheers
Cheers
My setup is very similar to my Duo2 setup. Although it runs cooler so if conditions allow it I run extra motor timing. You can go down a tooth to start to be safe. Start with 0 motor timing as well.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 01-05-2011, 09:38 AM   #210
OK let me do the math for you....
Endbell = 1.417" diam
X 3.14 = 4.449" Circumference
/ 360 (degree) = .0124" per degree
Each hash mark is roughly .025" thick (double the per degree measurement, meaning each hash mark is 2 degrees)
Each space in between the hash marks is the same .025" thick. (again double the per degree measurement meaning each "blank spot" is 2 degree)
SO....... That means if you move the adjustment from the beginning of a painted mark to the end of the painted mark (or beginning of the blank mark) you have moved 2 degrees. If you move again to the beginning of the next paint mark you have moved it 4 degrees.
That make it clear now?
Jimmy Wright
