Old 12-14-2010, 07:31 PM   #166
Trader Rating: 25 (100%+)
Default watts?
Anyone know how much watts does 10.5 have?
RustyRC is offline   Reply With Quote
Old 12-14-2010, 10:06 PM   #167
Johnny Wishbone's Avatar
Originally Posted by EAMotorsports View Post
Hey Windsor Thanks for the support! Normally I start with no timing on the motor with open class and once I feel like I have found the correct gear (usually close for all good size tracks) and I want just a little more I'll start adding timing to the motor. I will try to post a picture of a dyno sheet tonight at 0 and full timing so you guys can see the difference. Its not as much as you think but does make a difference.
At Vegas with the duo 2 I was about 2 notches past 0 in the open class with a 6.3FDR. I think my setup is on the Tekin site for the speedo settings.
EA
Any luck with that dyno sheet picture?
Also wondering what you use to get your rotor readings? Do you use a Trinity/EPIC unit or something else?
Thanks again.
Gary Lanzer
Old 12-15-2010, 08:07 PM   #168
Madulla's Avatar
Does the Duo 3 work with the Speed Passion Citrix??? I have read different things. Some say it works fine others don't
Madulla is offline   Reply With Quote
Old 12-15-2010, 08:44 PM   #169
M-Technic's Avatar
Trader Rating: 15 (100%+)
I think it depends on which generation Cirtix you have. I've heard that the early Cirtix ESC's don't play well with some motors.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 12-16-2010, 07:59 AM   #170
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I have the Cirtix with the USVTA sticker on the box. I was able to get the D3 to work.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 12-16-2010, 01:53 PM   #171
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
How do the D3 13.5s perform compared to other motors such as the SP V3 13.5? Anyone done any testing? Also What is the max timing you can run on these motors on the can?
Thanks in advance!
Fast XXXS is offline   Reply With Quote
Old 12-16-2010, 08:09 PM   #172
just ordered 4.5T D3 motor......can't wait to test against my friend's LRP X12
Marco926 is offline   Reply With Quote
Old 12-16-2010, 08:12 PM   #173
rendcool's Avatar
what's the difference between D3 "monster horsepower" and "black knight" ?
Itami o shitte ..
rendcool is offline   Reply With Quote
Old 12-16-2010, 08:20 PM   #174
Swampracer's Avatar
Trader Rating: 69 (99%+)
Default Black knight
The "Black Knight" is the Express Motorsports tuned version of the stock DUO 3 motors
Swampracer is offline   Reply With Quote
Old 12-16-2010, 10:31 PM   #175
Mowell's Avatar
I have mine at full timing and geared at 4.15FDR.
EA
Have you guys had much track time to test a FDR around 3-3.5 with no timing vs 4.15-4.25 with max. Someone earlier posted that it made more wattage everywhere with full timing, so I'd assume its faster at 4.xx, but I haven't had a chance to test first hand though.
TC6, Ten SCTE, Novak, Fantom, Savox, Spektrum
Mowell is offline   Reply With Quote
Old 12-20-2010, 09:44 AM   #176
Racecrafter's Avatar
Trader Rating: 25 (96%+)
Test results are in.....
Pres and I ran the Fantom 17.5 Ion3 in 1/12 yesterday with great results. I previously was running an Ion1 whereas Pres was running a SP v3.0. From my Ion1 set up I went up 2 teeth, lowered the boost and lowered the turbo on the ESC. My result was quicker & more consistent runs.
Our roll outs both were in the 85.5 range.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 12-20-2010, 10:07 AM   #177
csracing's Avatar
Trader Rating: 22 (100%+)
Ran my new 17.5T D3 friday night. I'm running off-road so it's not a direct apples to apples comparison..
Previously running a ballistic with some boost and turbo. Ran the D3 with the speedo in spec mode. Went up 1 tooth and tried running the motor at full mechanical timing advance. It was really soft down low. Ended up going back to the same pinion I had been running with the ballistic and 2 knotches of timing and it seemed better. 8.11 FDR for what it's worth. Lap times and overall time was the same with the D3 as the ballistic with the boost but felt a little softer overall. I was getting pulled out of a couple of the corners just a little bit, but I wasn't getting passed.
Still learning what the motor wants but I matched my track record, best lap times, top qualified and won so I'd say it was a good first outing.
CSR
csracing is offline   Reply With Quote
Old 12-20-2010, 10:19 AM   #178
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Hey Jimmy, your cars were quick yesterday.
Can you post your RS settings ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-20-2010, 12:45 PM   #179
WIITA's Avatar
Trader Rating: 42 (100%+)
and what size track you were running on. Thanks
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 12-20-2010, 02:05 PM   #180
90x45
http://www.tqrcracing.com/
