Old 09-14-2010, 07:05 PM   #31
Drew Ellis's Avatar
Jimmy shouldn't you be doing real work....Great app.
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 09-14-2010, 08:57 PM   #32
jrp
jrp's Avatar
Trader Rating: 18 (100%+)
Just posted another update to Gears! v1.3
Added support for Android 1.5
Added auto-calculation as you change the values (if everything is filled out).
Please let me know if you have any issues.
Also, folks with small screens, how does the UI look ? Does it scroll off the right side of the screen ? Trying to use the emulators but results vary...
jrp is offline   Reply With Quote
Old 09-14-2010, 09:09 PM   #33
troyer25's Avatar
Great idea, force close on HTC hero, hope it works by the time carpet season rolls around
G2 Designs,Team CRC, Hobbywing North America,Dumper's Speed Shop,CRC Raceway and Hobbies
troyer25 is offline   Reply With Quote
Old 09-14-2010, 09:34 PM   #34
jrp
jrp's Avatar
What version of the app were you running ? the newest 1.3 that I just released ?
What version of Android are you running ? You are the first to report any issues.
I don't have an HTC Hero to run myself, but I might be able to run something similar in the emulator.
Anybody else have this issue ?
Old 09-14-2010, 10:54 PM   #35
Bishop's Avatar
Yeah, app won't load on my Quench requiring force close, so either the 1.5 compile has not fully worked, or maybe it is my version phone.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 09-15-2010, 03:35 AM   #36
troyer25's Avatar
Running v1.3, have to force close when it loads, running android 1.5,
Old 09-15-2010, 07:51 AM   #37
jrp
jrp's Avatar
ok, sounds like it is a Android 1.5 thing. I will try to see if I can figure it out in the Emulator this evening.
Old 09-15-2010, 08:28 AM   #38
jrp
jrp's Avatar
Default Update
OK, just uploaded an application update, v1.3.1, that I think will fix the program on Android 1.5 devices. I was able to simulate the force close in the Emulator. You Android 1.5 guys please let me know if it works for you.
Old 09-15-2010, 08:45 AM   #39
Bishop's Avatar
Yep, it works now, thanks.
QRCCRA
www.qrccra.org.au
Old 09-15-2010, 08:45 AM   #40
Deebs's Avatar
ahhh! Found it!
very cool - thanks!
Denise Clarke
Where are the Girl Racers at?
RC America/ Xray | Picco Torque | Matrix | Radiopost | Speed PassionUSA | Upgrade RC | Dialed Inc. | P3 Graphics | Team Butter
Deebs is offline   Reply With Quote
Old 09-15-2010, 11:43 AM   #41
ngo8's Avatar
Send a message via ICQ to ngo8
Hey man thats a great app i just installed it on my Nexus One running on CM 6 stable and it works great so far no force close or anything ,keep up the great work .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 09-15-2010, 02:41 PM   #42
MackanG's Avatar
Hi
There is a problem if you 'r not using English on the phone. I use Swedish settings on my phone. Then problem is that we write 1,00 and not 1.00
If I write 1,00 in int. ratio it says there is no value in that field, and if I write 1.00 in ratio and 44.00 in tire dia I get a forced closed. Can you change the properties for those fields so you can us , or .
If I switch the phone to English, program is working without a problem.
MackanG is offline   Reply With Quote
Old 09-15-2010, 02:48 PM   #43
jrp
jrp's Avatar
Originally Posted by MackanG View Post
Hi
You mean everyone in the world doesn't use English I will look into it first chance I get.
Old 09-21-2010, 03:42 PM   #44
jrp
jrp's Avatar
Hi
Ok, so here is the deal. Android cannot deal with the comma as a decimal separator due to problems in the OS. These bugs may be fixed in later releases of Android, but that won't help most phones that are out there now. If you simply use the "period" as your decimal separator, will the app work on your phone set to Swedish ? Or does it fail in that manner too.
Old 09-21-2010, 05:19 PM   #45
tallyrc's Avatar
great app still man, thanks again. another app idea or an add-on to this one.. those of us with the advanced timing speedos could also use an mph/rpm claculating function for guessing at starting ending rpm values for the speedos.. also maybe a way of showing the fdr or rollout with the next size up and down pinions would e nice.. like say i figure based on 33t pinion, show 32 and 34 also.. some of us have room on the screens.. keep em coming..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
