Futaba CDR5000 or CE 35 GFX
Futaba CDR5000 hands down thats the only reason im using inferior chargers at the moment because I am waiting for it
and also money is no issue to me when it comes to rc
Originally posted by Tres
The Futaba looks nice(pics). I haven't them around yet, however.
The GFX is rock solid....
I would like to see the Futaba..
'Who's pocket are you in? This is a travisty, a sham, and a mockery. It's a travishamockery."
Guest
Originally posted by =MisFitz= NuKe
WHat?!? My friend, the Futaba charger is not any better that the GFX. The futaba may do 320293948 cells at once, and yes, it may also show you fancy graphs for each cell, but if you trust your battery matcher and did not get bubba to match your batts. then why would you need that feature anyways? You will know that your pack is bad when you start slowing down on the track. Plus, the GFX has a beutiful motor run feature. Also, if you know what to put the settings at on the cycle feature, that is one of the best things you can find on a charger.
Guest
Originally posted by Griffin
How can you say it's the best when you haven't used one?
Guest
It does not have the motor run-in feature but it does charge RX/TX pack at the same time as the main battery. The thermo function is also nice as it provides yet another safeguard for overcharging.
I think the GFX is a very good charger and I would not hesitate to get that either. But I really like the individual cell feature and the Futaba is just a heck lot smaller and lighter than the GFX.
Originally posted by jeffreylin
I have the Futaba. The individual cell voltage feature during discharge is very useful as it identifies the bad cell in the pack. It is also useful in the sense that you may FEEL that one pack has more punch than the other but with this charger you will KNOW for sure which one has less IR and more voltage in different stage of discharge.
Guest
If it could zap the cells .....thats something else.... I'll get it!
Originally posted by tornado
CDC V6 would give the readings like IR and ave voltage of your pack and you don't need the individual cell readings to tell you which the bad cell is. The pack will feel like s**t when its screwed......we have the trusty old digital voltmeter to find the culprit. To me the Futaba charger is just another charger with 6 digital voltmeter and is able to plot the graph from the data acquired. No offense...just my $0.02.
where did you buy it I want one
