Much More Charger be crazy 45 amp chargerr   >
Old 09-12-2010, 05:31 AM
angel.sosa's Avatar
Default Much More Charger be crazy 45 amp chargerr
Hello when I connect the charger, the display marks 45 amp, has it happened to someone? Has it solution?
I have put in touch with much more, but they do not answer
best regards from spain
angel.sosa is offline
Old 09-15-2010, 04:27 AM
angel.sosa's Avatar
is posible reset the charger?
Old 09-15-2010, 04:31 AM
yokemad's Avatar
Change it with a Real Charger
Hyperion
yokemad is offline
Old 09-15-2010, 07:11 AM
MikeXray's Avatar
Trader Rating: 73 (100%+)
Its likely 4.5amp adjust it and see what the max is..
MikeXray is offline
Old 09-15-2010, 07:15 AM
Team EAM
Trader Rating: 79 (100%+)
I got two of the legend chargers and out of the box one shows the battery voltage at 33 volts. The other one shows amp rate and mah increasing but battery voltage never increases. It shows it put 6800 mah into a 5600mah battery but voltage was still at 3.7 (single cell). I like their stuff but they need to get the issues fixed asap. 600.00 and I got some pretty boxes to stare at!
EA
EAMotorsports is offline
Old 09-15-2010, 07:53 AM
whipnet's Avatar
Man, when they say "Much More" charger they really mean it!
whipnet is offline
Old 09-15-2010, 05:29 PM
angel.sosa's Avatar
It is incredible... I always have trusted in this brand, and I am sad now... There is some possibility of reset the charger and to leave it like in his origin?
