Old 06-21-2004, 05:39 PM   #1
j240z's Avatar
Default How do YOU assemble loose cells ?
Just looking for good techniques/suggestions on assembling loose cells. The pack will be for a TC3. I have my eye on Dean's speed jig. I've also heard you can shoe-goo the cells together...? What's a good way to go about doing this. Which step should I start with. And do different brand battery bars really make a big difference? Is there a certain temp for soldering to cells? Thanks
j240z is offline   Reply With Quote
Old 06-21-2004, 05:45 PM   #2
F1Junkie's Avatar
R/C Tech Charter Subscriber
Get the Deans Jig. Well worth the money. For mine I had to dremel one of the ribs off to hold the longer cells - they may have changed it since then...
Take a look at
http://www.balakracing.com/buildingbatterypacks.htm
This should give you more than enough info...
Good luck
Dave
F1Junkie is offline   Reply With Quote
Old 06-21-2004, 05:52 PM   #3
j240z's Avatar
Smile GREAT INFO!
Thanks for the link! That's exactly was I was looking for
Old 06-21-2004, 06:32 PM   #4
Suspended
cr250 is offline   Reply With Quote
Old 06-21-2004, 06:54 PM   #5
popsracer's Avatar
j240z;
I too have the older DEANS Jig and had to cut off the rail from one side. The newer versions have been changed to work with 3300's.
If you have plenty of room on the sides of your Chassis, any brand of battery bar should work just fine. Some brands lay flatter on the cells and offer more clearance when up against tight chassis rails.
When soldering, hotter is better. You want to be able to complete each joint in a few seconds to avoid transfering too much heat to the Cells and possibly damaging them.
popsracer is offline   Reply With Quote
Old 06-21-2004, 11:42 PM   #6
j240z's Avatar
Cool. Thanks for all the help!!!
Old 06-22-2004, 12:34 AM   #7
Aurra Sing's Avatar
I use the Deans jig and clean the ends of the battery with motor spray. I tin the ends with a very little amount of solder (as little as possible is best). I heard silver bars have the least resistance so I always use silver ones. I've seen guys use shoo goo between the cells, seems to hodl the cells like a brick!
Aurra Sing is offline   Reply With Quote
Loose cells R/C Lidz R/C Items: For Sale/Trade 3 11-26-2006 06:52 AM
Loose cells XingXing Electric On-Road 8 05-19-2006 01:45 AM
Wtb: Loose Cells!!! dynasty R/C Items: Wanted to Buy 2 03-12-2005 10:20 AM
WTB: GT7 or V7.1 or GP3300 loose cells trinityguy21 R/C Items: Wanted to Buy 0 10-07-2003 02:42 PM
Matching loose cells JohnA Electric On-Road 6 07-02-2003 08:44 PM
