Like Tree4Likes
Tamiya TRF417
Old 05-07-2011, 06:13 AM
  #1366
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Sean Williams
Awesome post Craig!
What happened to you at the West Coast race? I was hoping Team Tamiya would get out of last place.
syndr0me is offline
Old 05-08-2011, 02:16 PM
  #1367
Tron's Avatar
Trader Rating: 17 (100%+)
Yeah dude why didn't you come back on race day? I needed some tips, I was one spot away from the podium in stock sedan
Tron is offline
Old 05-08-2011, 06:41 PM
  #1368
Vicko's Avatar
Trader Rating: 14 (100%+)
So has anyone see the Gear Diff 2, that comes in the new 417 kit?
is it al new?
Vicko is offline
Old 05-09-2011, 04:54 AM
  #1369
is it al new?
It is all new, no spec-r c**p lol
Will look something like this:
(Thanks to Kentech for the piccy! :-) )
Smartypants is offline
Old 05-09-2011, 06:42 AM
  #1370
Vicko! When ya coming out to run mod?
M3dreamin2008 is offline
Old 05-09-2011, 08:30 AM
  #1371
entitymugenmtx's Avatar
Trader Rating: 85 (100%+)
Almost done
entitymugenmtx is offline
Old 05-09-2011, 08:35 AM
  #1372
kedal's Avatar
Very nice !
What is the spure gear ?
kedal is offline
Old 05-09-2011, 09:03 AM
  #1373
Originally Posted by kedal
Very nice !
98T SPUR
Old 05-09-2011, 10:04 AM
  #1374
kedal's Avatar
Originally Posted by entitymugenmtx
98T SPUR
What brand ?
kedal is offline
Old 05-09-2011, 11:36 AM
  #1375
xenon spur
Old 05-09-2011, 05:21 PM
  #1376
Vicko's Avatar
M3 when it gets warmer LOL dont like the 50's in the moring
Vicko is offline
Old 05-09-2011, 09:16 PM
  #1377
Trader Rating: 20 (100%+)
Whazzup Tron!
I wish I could have made it back for a second day, unfortunately my brothers were in town and I only had a one day pass to race..... Plus my top deck was snapped in half from the front straight impact from Drew...car was just never right after that.
See ya at the next one tho!
Sean Williams is offline
Old 05-09-2011, 11:02 PM
  #1378
Originally Posted by Elliott Harper
Hi, yeah, harder oil in the rear gear diff will give more on power steering but a little less into the corner... I prefer the gear diff as there is no slip compared to the ball diff
You can also try things like less rear toe like you mentioned and a stagger in ride height (little higher rear)
Hope this helps
Thanks for the help, sins then I have opened the diff and noticed the oil was all gone. What's the best way to prevent this, I have rebuilt it with greenslim in the out drive and on both sides if the gasket. I have the white gasket is it the right one?
What turn motor would you use on a med small technical track with sp esc and turbo software, 7.5t, 6.5t, 5.5t or lower?
charl mac is offline
Old 05-10-2011, 05:25 AM
  #1379
crabboy's Avatar
Trader Rating: 58 (98%+)
Make sure you are using the "X" rings and the new gaskets are green but even with all the new parts you will still need to fill/check the oil level often, as for motors 5.5 or a 5 are good ones with no boost.
Rhys
crabboy is offline
Old 05-10-2011, 07:51 AM
  #1380
I think crabboy's post should help you
Im not really sure how you can stop the leaking im afraid...
I think if you use an SP motor, you could try 4.0 or 4.5, if you use like an Orion motor, use 4.5 I think you should use the standard 205 mod software
Elliott Harper is offline
