Like Tree4Likes
Tamiya TRF417
Old 02-18-2011, 11:44 AM
  #766
Originally Posted by M3dreamin2008
Wow didn't know that
Did you forget that our indoor asphalt track is sprayed with a light mist of WD40 every so often. See you tomorrow.
SRW141 is offline
Old 02-18-2011, 12:37 PM
  #767
cyclone speed's Avatar
Hehe, thanks for all the reply's and info guys
I sprayed some on my desk and now it stinks and is all greasy xD, but I will deffo try it out tomorow on the track on the tires.
But if its an oiled based solution, isn't it possible to spray some WD40 on the tires, and then apply some solvent solution to remove the oil quicker ?
cyclone speed is offline
Old 02-18-2011, 12:51 PM
  #768
For running ooutdoor asphalt, you can clean with wd40 after dry apply your traction compound.
SRW141 is offline
Old 02-19-2011, 09:50 AM
  #769
Hello, raced my car today , the car itself was great, no problems, could keep up with some 10.5 racers seeing that it was easy and great to drive.
But then came the crashes , I broke a master block and a rear wishbone, is it worth getting the split blocks ? And also bent a little bit a driveshaft ... so I'll probably get the steel ones, but shall I get the 46 mm or the 44 one's ?
Cheers again
Old 02-19-2011, 10:08 AM
  #770
jonest's Avatar
Cheers again
Get some steel driveshafts.... 44mm on front and rear.
jonest is offline
Old 02-19-2011, 10:26 AM
  #771
Cheers, will get them.
Another thing, are the split blocks from the TB-03 interchangeable with the 417 ?
And is it worth getting the gear diff by taming for the rear ?
Old 02-19-2011, 10:31 AM
  #772
jonest's Avatar
Split Blocks are compatible with 416 & 417 while gear diff is a personal choice. Some like it some don't.
jonest is offline
Old 02-19-2011, 10:42 AM
  #773
syndr0me's Avatar
Trader Rating: 32 (100%+)
Get 46mm steel for the front, the spool cups will last much longer. Steel in the rear doesn't matter so much.
syndr0me is offline
Old 02-19-2011, 10:46 AM
  #774
Ok, I'll see what my LBS has.
So according to honest, I can't use TB-03 split blocks on my 417?
As I've been looking on rcmarket and he doesn't have the 417 split blocks.
Old 02-19-2011, 12:06 PM
  #775
jonest's Avatar
Can use TB03 Split Blocks!
jonest is offline
Old 02-19-2011, 12:31 PM
  #776
Ah ok great !
Thanks alot mate
Will order them.
Old 02-19-2011, 09:24 PM
  #777
When running a gear diff I had to run 44mm... Just an FYI for you guys that want to run double gear diffs.
Kody is offline
Old 02-19-2011, 11:47 PM
  #778
syndr0me's Avatar
Oh yeah, same here. 44mm steel for front gear diff. 46 for front spool.
Kody, you running the extra long links like Jilles? Change his birds setup much? I guess I'll start with it in ABQ. I'll be surprised if I traction roll with Solaris.
syndr0me is offline
Old 02-20-2011, 01:29 AM
  #779
CraigM's Avatar
Trader Rating: 34 (100%+)
Steel bones last a lot longer in the back too, the aluminium ones are about as hard as a block of cheese so get sloppy very quick
CraigM is offline
Old 02-20-2011, 02:44 AM
  #780
Hello, i just noticed i bent a suspension shaft ( the 46mm titanium coated shaft that goes through the wishbone ) ... is it possible to use the one from my HB cyclone ?
