Like Tree4Likes
Tamiya TRF417
Old 09-17-2012, 06:35 AM
  #3916
Originally Posted by yobouno
Thanks Taman, not the cheapest out there, but hopefully they have one in stock.
Anyone has any wisdom on getting the car built right with a setup to share?
cheers.
See this:
http://www.petitrc.com/reglages/tami...miyaTRF417.htm
I personally really like the ETS setup from marc rheinard and viktor wilck. You can browse through these setups and see kind of a common base setup. Sometimes they deviate with 0.5mm shims somewhere etc but this is really just finetuning. There are also build tips in this thread.
GL
napoleon1981 is offline
Old 09-17-2012, 03:07 PM
  #3917
yobouno's Avatar
Originally Posted by napoleon1981
See this:
GL
Thanks.
yobouno is offline
Old 09-17-2012, 05:27 PM
  #3918
CL
CL's Avatar
Trader Rating: 34 (100%+)
cheers.
You can also try to get one from here:
http://shopping.rcmodel.hk/product_i...ducts_id=19156
CL is offline
Old 09-17-2012, 11:10 PM
  #3919
cheers.
I don't know where u live, but try modellbau seidel, its in Germany but the have some good prices.
plus they have Trf417x in stock
Cp Grafix is offline
Old 09-17-2012, 11:17 PM
  #3920
Hi Craig M, I have bought a Cso lower deck.
I don't have problems with it jet, it flat and the deck is 2,25mm all around.
i have just put it on my car, and without any isuses.
I drive on carpet track this winter, hopefully the car as outdoors.
Anyone got a good starting point for med carpet with sorex 28 jb's.
Old 09-18-2012, 02:13 PM
  #3921
NItrox416's Avatar
Hi all,
someone could explain me the difference in the set up between D/D, C/C, C/B in the front.
Excuse me for the quite silly question but I've just exchanged my trf416 with a trf417x
Thanks for help
NItrox416 is offline
Old 09-18-2012, 02:33 PM
  #3922
CraigM's Avatar
Originally Posted by NItrox416
Hi all,
Thanks for help
C/C is narrower than D/D so the front will roll more, but the shocks are laid down more with D/D so the steering is smoother. C/B introduces 0.5 degree arm sweep over C/C which gets the car into the corner better, this is most noticeable in tight corners where you will have a lot more steering. Generally D/D is used on large flowing tracks, and C/B everywhere else.
CraigM is offline
Old 09-18-2012, 02:41 PM
  #3923
CraigM's Avatar
FYI guys I've requested the mods update the name of this thread to "Tamiya TRF417 / TRF417X / TRF417WX" so we can keep all the 417 info in the one place.
Now if December would just hurry up!
CraigM is offline
  #3924
yobouno's Avatar
They offer ridiculous postage price to send out of EU zone. I live in Australia. Anyway got one from Banzai Hobbies, not the cheapest at least they have one in stock and their website looks reliable. Thanks everyone.
yobouno is offline
Old 09-19-2012, 06:15 AM
  #3925
NItrox416's Avatar
Arm sweep gets better the car into the corner and so gives you less steering in the exit? In the setups I saw on petitrc, also from yours, that is used usually c/b and d/b I'd never seen d/c, there is a particularly reason?
Thank you very much for the help.
Old 09-19-2012, 07:17 AM
  #3926
Smokem Racing's Avatar
Our new 417MX chassis have just arrived - http://www.smokem-racing.com/417MX.html.
Limited stock available on the first run so get in quick!
Smokem Racing is offline
Old 09-19-2012, 04:08 PM
  #3927
CraigM's Avatar
Normally C/B D/B is for technical tracks and D/D for large tracks. You don't normally need sweep on large tracks because they rarely have slow hairpins, but I'm sure D/C could work some places if C/B gave too much steering.
Maybe I didn't explain myself clearly. Sweep gives more castor as the car rolls, so when I say "gets into the corner better" I mean it has more steering and rotation as the car gets towards the apex.
CraigM is offline
Old 09-19-2012, 10:52 PM
  #3928
yobouno's Avatar
This discussion interest me, why would you set your toe using the suspension mount instead of using your steering linkage? What is your final toe on the front of the car?
I was planning to set mine up with the following:
front toe +2
front camber -1.5
2 holes damper with soft oil and medium spring
rear toe -4
rear camber -1.5
3 holes damper with soft oil and soft spring
The track I race in is medium size track in Adelaide, half technical half speed. Any help would be greatly appreciated.
yobouno is offline
Old 09-19-2012, 11:22 PM
  #3929
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
front toe +2
front camber -1.5
rear toe -4
rear camber -1.5
Others might come up with better explanations, but with regard to sweep, have a careful read of this. Toe and sweep are related, but distinct tuning options. I can't say I understand them, but guys like Craig are consistently fast, so I tend to listen to them.
On that basis, check out Craig's setups, which are well suited to medium outdoor tracks, just like our home track at SMA. His blog at http://tchub.wordpress.com/ is worth having a look at.
For a personal introduction, come over for the NSW State Titles in October
Phil.
PDR is offline
Old 09-19-2012, 11:55 PM
  #3930
yobouno's Avatar
Phil.
thx
yobouno is offline
