Like Tree4Likes
Tamiya TRF417
Old 03-14-2012, 09:14 AM
  #2866
RC MARKET's Avatar
Tamiya released Double Caldan Joint Shaft & Parts
Rc Market
Attached Thumbnails Tamiya TRF417-ta-42216.jpg   Tamiya TRF417-ta-42217.jpg   Tamiya TRF417-ta-42218.jpg   Tamiya TRF417-ta-42219.jpg   Tamiya TRF417-ta-42221.jpg
RC MARKET is offline
Old 03-14-2012, 11:45 AM
  #2867
Rc Market
Interesting, its stronger than arrowmax or specr DCJ ?
ezh_m5 is offline
Old 03-14-2012, 12:05 PM
  #2868
columbia-mk2's Avatar
Hi, has anyone tried if fits a 38 pinion with 98 spur gear? Are the motor mount holes long enough?
Cheers!
columbia-mk2 is offline
Old 03-14-2012, 12:16 PM
  #2869
RC MARKET's Avatar
Tamiya is Steel
Arrowmax is Spring Steel stronger than specr !
Old 03-14-2012, 01:59 PM
  #2870
CraigM's Avatar
Trader Rating: 34 (100%+)
Tamiya ones are stronger than arrowmax and the pins are retained with clips instead of grub screws so wont snap
CraigM is offline
Old 03-14-2012, 03:37 PM
  #2871
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
So, I sold my TC6 (first TC) and I am looking into a Tamiya.
Here's the question...I can get a 416x with Exotek chassis, gear diffs, ball diffs, and parts for about 250 less than the 417x. Is it worth the extra coin to get the 417x? It will only be run on asphalt.
Yeti AS3 is offline
Old 03-14-2012, 04:43 PM
  #2872
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
anyone know where i can buy the 3mm metric screws used in the 417x kit (or something similar)? they are super nice....
hanulec is offline
Old 03-14-2012, 08:22 PM
  #2873
Just buy a 417x. Take all the screws and give me the rest of the car. I'll even pay the shipping.
Juan Aveytia is offline
Old 03-14-2012, 08:37 PM
  #2874
chrisk's Avatar
Trader Rating: 32 (100%+)
Just go to your local nut and bolt shop and buy them.
You can also buy tamiya spares in alloy or there are titanium sets available
But can be expensive, local nut bolt store will be your best and cheapest option.
I bought heaps and keep them as spares
chrisk is offline
Old 03-14-2012, 09:11 PM
  #2875
hanulec's Avatar
yeah, right...
i've already done that through mcmaster.com for my existing touring cars. the screws on a 417x just look so nice... i'd like to have them on all of my cars (without buying them from tamiya usa in packs of 4 pcs)
hanulec is offline
Old 03-14-2012, 10:53 PM
  #2876
hotdognobun's Avatar
darn i just threw away all mine after upgrading to titanium/aluminum
hotdognobun is offline
Old 03-15-2012, 01:48 AM
  #2877
Has anyone used ta-53826 on trf417?
The problem is that it is necessary to use the washer, but if they put it on top of hub, so ballstud deep enough screwed into the hub.
PS: I bought a DCJ by tamiya, let's see how good they are
ezh_m5 is offline
Old 03-15-2012, 02:16 AM
  #2878
Well the 53826 is a little longer in the top kingpin the org. ones, so I guess u need a 1mm or 2mm skim besides the 7mm which comes which the kit.
Cp Grafix is offline
Old 03-15-2012, 08:45 AM
  #2879
I installed how in the photo, the lower king pin mounted flange down and 1mm washer between the hub and ballstud.
ps, see post 2881
ezh_m5 is offline
Old 03-15-2012, 09:54 AM
  #2880
Pro10noob's Avatar
Why not use the top flange mount on the bottum with the flange from the inside of the C-hub?
This will create less room so you need a thinner spacer(the blue one)
regards Roy
Pro10noob is offline
