Like Tree4Likes
Tamiya TRF417
Old 08-30-2011, 05:18 AM
  #1846
tmomedrano's Avatar
Default have you guys tried front gear diff with putty?
as the title says:
what was your experience?
tmomedrano is offline
Old 08-30-2011, 07:02 AM
  #1847
Trader Rating: 27 (100%+)
Originally Posted by tmomedrano
as the title says:
The kneaded putty front gear diff is great on asphalt. Suggest changing the putty after 40 or so runs. The putty doesnt break down but does become a smoother in texture. Imagine keeping any material in a mixer for too long. It will start of smooth-out. Not a big difference but will change the car feel.
Havent ran the putty yet on carpet but expect to have some feedback there by the end of this weekend. Usually keep a 300-500K gear diff and putty diff on hand.
MDawson is offline
Old 08-30-2011, 07:45 AM
  #1848
TryHard's Avatar
In my experience so far....
Indoor, on a tight and twisty track with high grip, gear diff in the front (putty or 500K oil) was faster than a spool, more than anything because steering is king. The car also carried better mid-corner speed, not washing out, so basically gained back from entry to middle more than it lost on exit..
However, outdoors, on a much larger and more flowing track, spool is still faster. Mainly thats down to drive off the turn. Quite simply, can't beat a spool for drive. Yes it steers less, but the corners aren't as tight, and the laptimes don't lie...
Hence why I wouldn't say one is the magic ticket... you need to try both sorts out, and see which best suits your style/track.
HiH
Ed
TryHard is offline
Old 08-31-2011, 08:25 AM
  #1849
jonest's Avatar
HiH
Ed
totally agree!
jonest is offline
Old 08-31-2011, 11:28 AM
  #1850
HiH
Ed
Are you using 500k oil from traxxas? What kind of puddy do you recommend?
So far I have been unable to get a front gear diff to work well. I would be interested in trying it out with the thicker solutions inside.
Will want to try this out in Vegas...
TheZoof is offline
Old 08-31-2011, 09:18 PM
  #1851
TryHard's Avatar
I'm using Kyosho 500K, seems to be one of the only ones can find. Can also use the aforementioned putty, and OFNA Diff-Lock fluid is something else I would like to try out at some stage.
HiH
Ed
TryHard is offline
Old 08-31-2011, 11:55 PM
  #1852
how much imporve on this kit compare to 416x? i was using xray but they change every yr! really hard to keep up update my kit!
Mike-Xray is offline
Old 09-01-2011, 01:05 PM
  #1853
HiH
Ed
Ed,
OFNA diff lock works great! I've used it multiple times with great success. At first the diff is a bit tight, but once it breaks in; the consistency is held for a long time.....takes a lot to break down!
Turillo is offline
Old 09-02-2011, 12:57 AM
  #1854
kentech's Avatar
Default TRF417 at All Japan Nationals
More @ http://kentech.blogs.se/
kentech is offline
Old 09-03-2011, 09:10 AM
  #1855
GMartinez's Avatar
Trader Rating: 91 (100%+)
Default Updated version with Gear Diffs
For those that are still looking they just received 2 more kits
http://www.superiorhobbies.com/istar...id=TAM42200!SH
GMartinez is offline
Old 09-03-2011, 12:24 PM
  #1856
Trader Rating: 47 (100%+)
transplantlife is offline
Old 09-03-2011, 10:32 PM
  #1857
TryHard's Avatar
Originally Posted by kentech
Saw the pics.... check out the motor mount, that's no re-drilling of an original piece... pretty sure thats a two-piece prototype
Chassis plate is new too, extra triangular cuts on the inside edge of the cells give that away, as well as the cuts behind the suspension mounts.
TryHard is offline
Old 09-04-2011, 01:29 AM
  #1858
kentech's Avatar
Yes, new split middle bulkhead/ motor mount. And I belive on the chassis the cutout under the front diff/spool also extends further back. The car also has the same damper mount balls used at the worlds last year.
We're probably looking at the TRF417(?) to be displayed at the Tokyo Hobby Show in October, hence the reference to "the latest-spec TRF417" in the Tamiya text...
kentech is offline
Old 09-04-2011, 01:37 AM
  #1859
Geez another one will it also be coming with split mount suspension
Old 09-04-2011, 07:53 AM
  #1860
Starteur's Avatar
Here's a quick one for you guys:
What is the best Tamiya body to run in Sedan or GT1??
Was going to run B4 but it is discontinued!
Regards
Starteur is offline
