Old 06-18-2004, 08:50 AM   #1
Cardboard's Avatar
Send a message via AIM to Cardboard
Default V-blocks
Is there any other lubricant that could be substituded for graphite powder on the v-blocks of a lathe?
Also, in a related question, How can you check that the stands are perfectly perpendicular?
thanks, i'm off to take my regents now.....*gulp*....
Cardboard is offline   Reply With Quote
Old 06-18-2004, 10:52 AM   #2
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I use a bushing luve on the v-grooves, works prefectly fine.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 06-18-2004, 03:11 PM   #3
Default Re: V-blocks
I've always heard just use a lil bit of normal oil. Don't use silicon oil as it can cause chattering as it grabs.
To check for perpendicular on the stands you need to check the runout on the COMM. Measure one end and then the other and adjust accordingly. A zero difference would be great but I think I've read that .007 is acceptable.
Brian Anthony is offline   Reply With Quote
Old 06-18-2004, 06:33 PM   #4
Cardboard's Avatar
ok, thanks. I lined it up using a lego brick, so I think it should be fine.
One final question about lathes: Do I have to tighten down on those purple plastic clips? Or just leave them alone, as long as they hold the comm on the v-block as it spins?
Old 06-18-2004, 08:37 PM   #5
Moderator
You just tighten them enough to hold it in the grooves, otherwise it causes drag.
SMC Racing
Old 06-19-2004, 07:23 PM   #6
F1Junkie's Avatar
R/C Tech Charter Subscriber
Hey Cardboard -
did you get the battery yet?
Let me know...
Dave
F1Junkie is offline   Reply With Quote
Old 06-19-2004, 10:26 PM   #7
Cardboard's Avatar
Yep, left feedback too.
Old 06-20-2004, 03:47 PM   #8
F1Junkie's Avatar
Thanks a bunch!
Dave
Old 06-20-2004, 10:34 PM   #9
Entropy's Avatar
I bet you can build a lathe using lego bricks too..
Entropy is offline   Reply With Quote
Old 06-20-2004, 11:05 PM   #10
Still Bill's Avatar
I don't even use the purple plastic hold downs. Just have the armature in the V-blocks.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 06-22-2004, 08:27 PM   #11
Cardboard's Avatar
Thanks to everyone who helped on the few threads that I posted about lathes, I am very happy with my lathe and I didn't screw anything up yet.
thanks!
TRF415 blocks Customworksking R/C Items: Wanted to Buy 0 02-01-2007 02:40 PM
Reference Blocks?? simba350 Australian Racing 2 02-03-2006 05:16 PM
415 suspension blocks axle182 R/C Items: Wanted to Buy 0 01-31-2006 03:56 PM
TB-02 shims and sus.blocks? P956LH Electric On-Road 5 04-20-2005 06:58 PM
WOS steering blocks AustrianRacer Nitro On-Road 0 09-12-2004 11:08 AM
