Endurance Motor
Old 06-18-2004, 08:50 AM
  #46
rcsabah's Avatar
some race they do not allowed opening holes... normally we make air scope from side of chasis to blow the end bell
rcsabah is offline
Old 06-18-2004, 10:08 AM
  #47
Tech Legend
Wild Cherry's Avatar
have`nt try out the V2 endbell either.....
sould work great....>problem however,
no enduro brush`s available for V2 endbell...
Wild Cherry is offline
Old 06-18-2004, 10:40 AM
  #48
kufman's Avatar
the novak brushless will work for an endurance race if you put a small fan on the controller and gear the motor nicely. Also try to limit your use of the brakes as much as possible.
kufman is offline
Old 06-18-2004, 02:16 PM
  #49
fatdoggy's Avatar
Wild Cherry - Yes there are.
https://www.ssl-stormerhobbies.com/c...pl?pn=ORN41090
If your going to be running stand-up hoods the CS high silver brushes may be the way to go. You can get 40+ run out of them and their not very hard on the comm.
fatdoggy is offline
Old 06-18-2004, 04:12 PM
  #50
JimmyMac's Avatar
If I would have known brushless was legal... I would have gone for that. But for our enduro.. it's not. Go with the Novak System since you can obtain one.
JimmyMac is offline
Old 06-19-2004, 02:51 PM
  #51
i have just finished some development for mkyself.
ive got the peak dynasty with the v2 endbell,put bushes in and a 27 turn arm with medium-light spring combo and sprint brushes for 5min racing.
the arm is a monster stock arm,with the fixed timing this should be legal and be way the fastest motor.
i have tried it and its blisteringly fast.
for endurance though i should think it would out run/perform anything else.just put endurance brushes in.
trf racer is offline
Old 06-19-2004, 08:39 PM
  #52
Entropy's Avatar
No BL man..
Entropy is offline
Old 06-20-2004, 04:30 AM
  #53
Default correct gearing for my tc3
what pinion do you suggest for a 98 tooth spur, 64 pitch if you're running on a 9 turn triple wind motor?
droop1000 is offline
Old 06-21-2004, 10:23 AM
  #54
rcsabah's Avatar
track size? high speed or mickey mouse track?
rcsabah is offline
Old 06-24-2004, 03:51 AM
  #55
its a high speed track.
