JB-Orion tires!
Old 04-06-2002, 08:51 PM
Default JB-Orion tires!
hi guys, i would like to know how this tire performs on the track and its tire wear if possible. if this one is great, i'd want to switch for it from sorex. sorex rubber tires are great but it i can only use if for 2 race day!
comment on this JB-ORION tire pls. and compare to other brands like the sorex and take-off! thanks
maski is offline
Old 04-07-2002, 05:31 PM
seaball's Avatar
whoops, i didn't realize you said you've used the take offs. the take offs are very consistent and outlast the sorex's from what i understand. not the same grip, but enough so that a softer setup will produce the same or better results. and the wear is better than a sorex. sorry, i was just gonna recommend the take offs. never tried the orions. what's the hype on 'em, or have you not heard?
seaball is offline
Old 04-08-2002, 03:35 AM
seaball>
nope, i havent tried the take-offs. i'll give them a try this time since you said it wear better than sorex so that means i can use it longer!
i haven't heard anything about that jb-orion tires, if you do have pls share it with me!
maski is offline
Old 04-08-2002, 06:54 AM
51's Avatar
Default Team Orion Tires
I just got my first shipment from Orion that included a few sets of "A" and "B" tires. I ran the "B's" for the first time Friday night with great success. Normally our track favors Sorex 32's with HPI Green inserts (36's in the summer). I ran Orion "B" tires with HPI Greens and felt that the car was all around faster; cornered faster, acclerated faster, just overall better. The 32's that I had been running had about 5 runs on them compared to the brand new Orion "B's".
As far as wear, I think they were better than the Sorex's. At our track it seem to take about 3 runs to get the Sorex tires to "wear a layer off", then after that they are good for about 20 more runs. The Orion tires were awesome from the sound of the tone and show minimal wear after 4 runs.
Another nice thing about them is the wide temp ranges. I don't have the exact ranges, but "A" and "B" types will proably be used 90% of the time at most tracks (appx. 32 - 110 degrees track temp). The "C" and "D" compounds are for track temps between appx. 90 and 170 degrees.
-Brent Thielke AE/Orion/Proline
51 is offline
Old 04-08-2002, 08:59 AM
nice comparison between the sorex and orion tires. i'll probably try "C" since its pretty hot here. sorex are great tires and has lot of grip though i noticed its pretty thin.
i hope orion tires has a thicker rubber compared to the sorex, or maybe the same as yokomo 138s though 139s are thinner.
sorex, orion, take-off and yokomo tires are the only available at our LHS.
thanks for giving me your observation about the tire
maski is offline
Old 04-09-2002, 11:19 PM
seaball's Avatar
ya'know, i don't have any more input, but that's a great selection to have at your lhs. ours has yoks and sorex. i think the takeoffs are thicker. i really like them. the sorex's grip like hell, but temp sensitive, and so thin. i think it's that flex that gives them the mad grip. i recently went with some sorex 28's with hpi reds. they built up nicely with a fairly large gap. the tires are so thin. and are wearing poorly. i dunno. the takeoffs are nice, because they come with a decent molded insert that most people use. ok then, see ya.
seaball is offline
Old 04-10-2002, 05:55 PM
rcruv's Avatar
Default Re: Team Orion Tires
Originally posted by 51
I just got my first shipment from Orion that included a few sets of "A" and "B" tires. ---------------------------------------
What is the difference between A,B,C,Ds?
Is A the softest?
Thanks.
rcruv is offline
Old 04-10-2002, 06:23 PM
rcruv's Avatar
Never mind, I just got it!
#75001 27 B 0-45 C
#75002 32 C 10-55 C
#75000 35 A 20-65 C
#75003 40 D 40-75 C
rcruv is offline
Old 04-10-2002, 07:03 PM
Regional Moderator
daniz24's Avatar
Many top driver complains about this tires at Worlds Warm-up. It appeared that everyone was having problem with tires overheating and struggling to find a constant grip for the whole 5 minutes race duration, as the temperature of the track changed so much between morning, noon and afternoon, causing setup difficulties.
daniz24 is offline
Old 04-10-2002, 07:11 PM
rcruv's Avatar
Do you know what inserts, wheels they used?
Thank you.
rcruv is offline
Old 04-11-2002, 05:33 AM
51's Avatar
Default Inserts/Wheels At The Worlds
rcruv: According to the small race report on Team Orion's website the spec insert is the JB Blue (Medium-71002) or Black (Firm-71003). They reported that Hara was using JB Extra Hard wheels.
daniz24: Who did you hear this from?
...As you can see by rcruv's post I was incorrect about the temp ranges. Sorry, I didn't have the exact data with me when I posted.
51 is offline
Old 04-11-2002, 08:50 AM
Regional Moderator
daniz24's Avatar
Thank you.
Surikarn : RJ Ride inserts (maybe ) and Tamiya aerodish wheels
Masami : yokomo inserts and aerodish wheels
Hara : Orion / HB inserts and wheels (don't know for sure)
daniz24 is offline
Old 04-11-2002, 08:52 AM
Regional Moderator
daniz24's Avatar
Default Re: Inserts/Wheels At The Worlds
from Surikarn and many top drivers such as Masami, Adachi..... but not Hara (he's sponsored by Orion) LOL
daniz24 is offline
Old 04-11-2002, 12:12 PM
51's Avatar
Default Re: Re: Inserts/Wheels At The Worlds
In an ad for JB Foam they state that it was named the spec insert for the Worlds. I wonder why the other guys weren't using them to better prepare for the actual conditions. Maybe they (JB Foam) wasn't available to everyone?
...but yea it's nice to see that a tire Hara was key in developing was named the spec tire and that he did well with them.
51 is offline
Old 04-13-2002, 02:47 AM
rcruv> are your temp range for orion tires accurate? i thought its like 24-40 of sorex and a-d for orion!
seaball> i agree that sorex tires are alot thinner compared to other brands though i haven't tried take-off yet. my friend said they have lesser grip compared to the sorex.
at the pre world's race, they were using orion B tires so definitely they will have problem with overheating since its hot their.
maski is offline
