-   -   19t motor (https://www.rctech.net/forum/electric-road/43036-19t-motor.html)
piorc 06-17-2004 09:51 AM
19t motor
Hello, i just bought a 19t motor from integy, here is:
http://integy.automated-shops.com/cg...56104476546.64
and my question is : Is this a great 19t motor??
which motor you in usa use??
which is the best??
Thanks a lot.
SalvadoriRacing 06-17-2004 02:43 PM
reedy pt based.....
it's nothing but a reedy pt motor wiht 19turn arm....
what more can I say???
It's not a spec motor because the timing is adjustable...
in USA the drivers run the reedy 19t spec mostly, because the motor is usually handout for many races....
the reedy one is 24 fixed timing with 9mm arm while the integy/matrix has adjustable timing and the arm is 7.5mm, the matrix is and rpmish motor and you can adjust less than 24 degrees of timing which is really better for quadmags motors....
SalvadoriRacing 06-17-2004 02:47 PM
aaah!!!
i wrote about this motor....
http://integy.automated-shops.com/cg...05104447855.03
you're confusing the motors piorc.....
