Brush Serrator
Old 06-15-2004, 10:48 PM
Brush Serrator
What's the deal with these? I was wondering exactly what purpose they would serve. Would they allow me to use brushes longer, because I could re-serrate the faces? Or something else? Thanks.
micros_rock is offline
Old 06-15-2004, 11:20 PM
Trader Rating: 17 (100%+)
exactally.
Most of the serious racers run very hard brushes that wear every run or 2 and to buy a new set would cost alot so we just re serate them and run them again. Its just like getting a new set
Kave is offline
Old 06-16-2004, 12:40 AM
Yokomo Aust's Avatar
Default Serrator
I am not a serious racer but i dont want to waste a good brush just because the serrations are gone. I use the Fussy Brush unit to grind them down to smooth and then serrate them again. It seems to be a little bit fiddlier than the Integy electric brush serrator.
Yokomo Aust is offline
Old 06-16-2004, 03:54 AM
Also (only if you get really serious about it) slight amounts of spring tention will be lost with every re-serrate, so if at some point, power starts to drop off, re-tweak your spring pressure to pickup what youv'e lost ......you can make this type of measurement with a big jim fiddlestick or similar tool
Joe B is offline
Old 06-16-2004, 10:57 AM
Okay, so it looks like a brush serrator would be a good investment. Any ones on particular? It would be for stock laydown brushes.
