20R or 24R
Old 06-15-2004, 02:41 PM
rc_square24's Avatar
Default 20R or 24R
i'll be running rubbers on carpet and i have sorex 28,32R tires.
will get another set so i wanna know which is used more often, or "safe" to go with, 24's or 20's?
its a temporary carpet track FYI
rc_square24 is offline
Old 06-15-2004, 02:59 PM
Tek Nickal's Avatar
If its relevantly cool inside, use the 20s but if its hotter inside, use the 24s.
Tek Nickal is offline
Old 06-15-2004, 04:45 PM
Matt Howard's Avatar
28's in the front and 24's in the rear. If the traction is really low then you can try 24's in front and 20's in the rear, carefull though, you might traction roll.
Matt Howard is offline
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Hi You must be going to the big race in two week in Vancouver BC.. Most of the guy there used 20 in the rear and 24 in the front...Good luck
OVA is offline
Old 06-15-2004, 05:56 PM
Matt,
What inserts?
jrrc is offline
Old 06-15-2004, 06:04 PM
P2
P2's Avatar
Trader Rating: 15 (100%+)
I've used HPI reds with 28s/24s as Matt H suggested
P2 is offline
Old 06-15-2004, 06:10 PM
HPI reds or the Xenon Grey's worked good for me this past winter
Old 06-15-2004, 07:15 PM
well...for other people whos also goin to this race, it seems that theyre allowing foams now...
Old 06-15-2004, 07:21 PM
Joel Lagace's Avatar
I have had good luck with my SD using:
FRONT: 24 with blue hpi insert
REAR: 24 with green hpi insert
Joel Lagace is offline
Old 06-15-2004, 08:17 PM
as theyre allowing foams now...how much in laptime difference between rubbers and foams on carpet?
thanks for the replies!
Old 06-15-2004, 08:22 PM
oh and how are speedminds compared to jaco foams on carpet? cuz theyre alot cheaper!!
Old 06-15-2004, 08:29 PM
Foam will be faster the rubber .5 to 1 second a lap at least. )
As for pricing JACO and SMC now have a Vancouver based distributor so prices will be coming down soon
Old 06-16-2004, 02:15 PM
rcsabah's Avatar
any sample pic of carpet used for carpet race??
rcsabah is offline
Old 06-16-2004, 07:21 PM
no cuz itll be setup for this one race..thanks though
Old 06-16-2004, 08:04 PM
Mike Haynes's Avatar
Speedmind foams are crutty compared to a jaco, but the TRC is way better then both if you ask me.
Foam is a lot faster then rubber in mod and 19, but its closer in stock where traction isnt as important.
Mike Haynes is offline
