What bearing oil do you recommend >
Old 06-14-2004, 09:06 PM
  #16
Entropy's Avatar
Originally posted by alch
Alot of the racers here in Japan (including me) use F-Zero.
Good stuff but don't forget Gigalube depending on application...
Entropy is offline
Old 06-14-2004, 09:07 PM
  #17
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by 29Dennis
I would say Zubak's Speed Juice!!!!
Good stuff there
-Dave
JDM_DOHC_SiR is offline
Old 06-14-2004, 09:53 PM
  #18
FUK_WRX's Avatar
Originally posted by JDM_DOHC_SiR
Good stuff there
-Dave
Ok Zubak indeed but which one i think there are several type any part numbers
FUK_WRX is offline
Old 06-14-2004, 10:28 PM
  #19
utieh's Avatar
Atlas Respo with a dentist seringe
utieh is offline
Old 06-14-2004, 10:38 PM
  #20
this is the best stuff for stock motors.
http://www.shopatron.com/img/product.../SLKS7-426.jpg
syntex1 is offline
Old 06-14-2004, 10:47 PM
  #21
Yes i agree that is the best stuff, improved my laptimes by .0000000000001 sec. I swear by this stuff
Johnnytc3 is offline
Old 06-14-2004, 10:50 PM
  #22
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 39 (100%+)
Some of the bearing lubes i've use/used:
- Tri Flow
- Marvel Mystery Oil
- Royal Oil
- Prolong
- Tribo
- WD40
- 0W 30 Mobil One
All work pretty well, just make sure its consitency isn't too thick, and be sure to use one to two small drops.
RCBuddha is offline
Old 06-14-2004, 11:04 PM
  #23
of couse WD40
Loman is offline
Old 06-15-2004, 05:32 PM
  #24
-Dave
Old 06-16-2004, 03:05 AM
  #25
Thumbs up
Liquid teflon or graphite powder.
Mabuchi540 is offline
Old 06-16-2004, 03:15 AM
  #26
rough512's Avatar
Kindly specify which brand?
I tried Super Lube once, it has Teflon. I sprayed the oil into a film canister and soaked two good Tamiya bearings overnight. The bearings got messed up. I removed the seal and found white stuff blocking the small balls from turning smoothly.
It works great on plastic gears though (TA03)
rough512 is offline
Old 06-16-2004, 03:40 AM
  #27
Post
God now you're asking lol it was years ago I got it from my brother when he used to work in a machine shop (so I'll ask him if he can remember the name). But I do remember you DON'T soak them over night he said just take of the sheild and give them the lightest of sprays or else you'll over do it and it will go all glugy.
Old 06-16-2004, 04:59 AM
  #28
Tommy Bergfeldt's Avatar
Megamule
The only bearing oil i use.
Tommy Bergfeldt is offline
Old 06-16-2004, 05:42 AM
  #29
Gutter Ball's Avatar
Speed Juice is for comms, Speed Lube is for bearings
Gutter Ball is offline
