Completly discharged a NiMH
#16
Hmm, should I dischrage it all the way to 0.00v then dead short it and leave it for a few days and charge it again? BTW, I don't have a tray.
#17
Originally posted by FIRE RIDER
...hooked the pos to the neg and the neg to the pos for about 10-15 seconds no more than 30...
#18
#19
check, when you are charging the packs, what temp it reaches. if it is still relatively cold when it stops charging just increase the peak detection on the charger. i found that with my fukuyamas that they don't even get hot when charged, i increased the peak detection and they run better.
#20
The pack charges fine, it gets warm like it normally does. I don't think there is any bad cells in there, they all have the same voltage when charging.
